Wired back in the xenon HIDs, but...
greasemonkey1234
Hi Guys,
Right I re-wired in the JDM ballasts and put in EU (road legal) bulbs into the headlights. Now, I did the drivers side first to check that I had wired correctly and JOY I had a good quality light. I then wired up the second, passenger side light and no lights. The main beam works fine, as I understand this is on a different circuit, however, no lights from either now.
I thought a 15 amp fuse had blown but no, they all seemed fine. Does anbody know whether the HID's work on a different voltage or need a higher rated fuse?
Many thanks
Al
basic equation... power=voltage x current
so the current = power/voltage
so for example...
basic lamp = 12v
power= 55w
current?
so 55w/12v = 4.5 amps approx
xenon lamp=15000v
power= 35w
current?
so 35w / 15000v = 0.0023 amps...
i dont know what the input voltage of the transformer/ballast is but regardless the lamp power is less
in theory this is correct but im unsure of the exact values and if theres a current load on the transformer/ballast 12v supply side
