neo Posted October 7, 2006 Share Posted October 7, 2006 got stuck in some slow moving/stop/starting traffic on a dual carriageway today, finally managed to get off up a sliproad, turned right and booted it a little further down the road had to slow down, then both the warning lights under the rev counter light and lost all power pulled over to one side thinking the car had stalled but it hadn't, switched off the car, restarted first time but now the little engine warning lights on all the time, the car does drive like normal tho popped into the nearest dealer but all the service people had gone home, spoke to a salesman (who seemd to know loads about the Z), explained and he said it should be fine to drive, is it a dealer reset or ok to do a reset myself is this correct reset i need to try and do ? http://www.350z-tech.com/zwiki/Tutorial:ECU_Reset cheers Neo Quote Link to comment Share on other sites More sharing options...
lomoto Posted October 7, 2006 Share Posted October 7, 2006 you could just try switching the igntion on and off a few times and that works sometimes Quote Link to comment Share on other sites More sharing options...
neo Posted October 7, 2006 Author Share Posted October 7, 2006 also here http://www.350z-uk.com/forum/viewtopic.php?t=89 Quote Link to comment Share on other sites More sharing options...
Removed Posted October 7, 2006 Share Posted October 7, 2006 you checked the oil level? Quote Link to comment Share on other sites More sharing options...
neo Posted October 7, 2006 Author Share Posted October 7, 2006 did the other day but will check again as the car wasn't on the level oil pressure seemed fine while driving. Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted October 7, 2006 Share Posted October 7, 2006 My guess is it's a faulty sensor or something, dealers diagnostic equipment will pick it up. I wouldn't drive it tho unless it's totally necessary Quote Link to comment Share on other sites More sharing options...
