Chesterfield Posted December 31, 2005 Share Posted December 31, 2005 Specifications for the various variants are as follows: Coupe: Engine 3500cc V6 24V Power KW (PS) / RPM 206 (280) @ 6200* Torque Nm/RPM 363 @ 4800 Maximum Speed MPH 155 DIMENSIONS Length (mm) 4310 Width (mm) 1815 Height (mm) 1315 Roadster: GT4: 06 Coupe: http://www.nissanhelp.com/Models/2006/3 ... iption.htm bear with us, work in progress Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted October 12, 2006 Share Posted October 12, 2006 the width mentioned, is that including or excluding mirrors? Just wondering, coz i was looking for a house, and the garage door is 2120mm. Just thinking if i can park the car in it or not. (gotta have some priorities eh ) Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 12, 2006 Share Posted October 12, 2006 if you were excluding or including the mirrors as part of the width I think you'd still have a problem. You would at least need to allow another 450mm so you could open the door Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted October 12, 2006 Share Posted October 12, 2006 I m talking about the size of the garage door. Inside the garage there is enough space to open the door ofcourse Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 12, 2006 Share Posted October 12, 2006 phew Quote Link to comment Share on other sites More sharing options...
GrahamB Posted October 12, 2006 Share Posted October 12, 2006 why not just flip the nice little switch and draw the mirrors in? I suspect they would then be less wide than the rear wheel arches. Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted October 12, 2006 Share Posted October 12, 2006 Coz i dont have the "nice little switch" on my 2006 car ? Quote Link to comment Share on other sites More sharing options...
lomoto Posted October 12, 2006 Share Posted October 12, 2006 Coz i dont have the "nice little switch" on my 2006 car ? What no fold in mirrors?? Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted October 12, 2006 Share Posted October 12, 2006 its the switch thats supposed to be in front of the round button to move the mirrors, right? Well, i aint got one, unless i really missed it Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 12, 2006 Share Posted October 12, 2006 how weird Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted October 12, 2006 Share Posted October 12, 2006 Coz i dont have the "nice little switch" on my 2006 car ? Suppose they had to cut the cost with all your little adjustments Wonder if this is the case on UK models??? BTW width includes mirrors iirc Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted October 13, 2006 Share Posted October 13, 2006 No it doesnt. Found it on the net: width including mirrors 2019mm. That leaves 10cm Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted October 13, 2006 Share Posted October 13, 2006 No it doesnt. Found it on the net: width including mirrors 2019mm. That leaves 10cm Your screwed then Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted October 13, 2006 Share Posted October 13, 2006 Seems there was some error on the plan. The door is 2m43. Should fit just fine. Gonna check it out tomorrow Quote Link to comment Share on other sites More sharing options...
SimonKevNorris Posted December 26, 2008 Share Posted December 26, 2008 Coz i dont have the "nice little switch" on my 2006 car ? Suppose they had to cut the cost with all your little adjustments Wonder if this is the case on UK models??? BTW width includes mirrors iirc My new 350Z GT comes with the switch! Quote Link to comment Share on other sites More sharing options...
Walbertonio Posted June 24, 2009 Share Posted June 24, 2009 Apologies for dragging this post up again, but I wonder if anyone could help with a little query? Looking ahead, I'm trying to work out if I could get a 350 into my back yard which has a fairly steep ramp (don't have dimensions to hand, sorry, will grab 'em tomorrow). I've found measurements for wheelbase (2650mm) but the only hint on standard spec ride height I found from searching was 108mm in NZ - are UK cars the same or different, does anyone know, as a post from searching seemed to hint that 350's sold in Australia had a different ride height? Is this the right measurement I should be looking for? I understand it might be the oil pan which is the absolute lowest point on the underside? Our back lane is a little on the narrow side, and while we can fit a Focus & A4 in there fine, I'm having some doubts the rear end will clear the ramp on the turn, and of course if the underside behind the front wheels will clear it too. Any help with those measurements appreciated. Quote Link to comment Share on other sites More sharing options...
H5 Posted June 25, 2009 Share Posted June 25, 2009 I think you'd be best off seeing if there is a member nearby that could help out or even test drive one from a dealer and drive it to your place and see if it fits... Turning circles, suspension movement etc all make it an art rather than a science. I can drive onto my parents drive by coming off it I crunch my front bumper. Quote Link to comment Share on other sites More sharing options...
Walbertonio Posted June 25, 2009 Share Posted June 25, 2009 Aye very true, will have to see what options I can find locally, thanks! Quote Link to comment Share on other sites More sharing options...
DP7657 Posted July 2, 2011 Share Posted July 2, 2011 Has anyone tried squeezing through a 7 ft width restriction in the Zed? I've never had a problem with the things and am more than happy to do a normal width (7 "7) restriction in it but I had to shy away from a 7 yesterday, I believe that gives about 2 inches of room on each side?! Didn't fancy it myself, wondered if anyone else has been brave enough? ( Why do Bromley council feel the need to put these super narrow restrictions in anyway?) Quote Link to comment Share on other sites More sharing options...
