headlight improvment but not full upgrade
greasemonkey1234
Depending on how the company undid the ballast and bulb set up you may need hid bulbs as they probably would have put halogen ones in
Do you still have the power packs or have they removed them ?
I have some in stock if you need them
Cheers paul
the lamps work in 2 totally different ways, the xenon hid lamp works with an arc(like lightning) hence the need for the ballast... the normal lamp is a filament lamp which lights due to resistance. The ballast will probs blow the lamp to bits as the current rating on the hid is very low but the voltage very high
