km002916 Posted October 25, 2010 Share Posted October 25, 2010 Been on the hunt for some second hand 10mm spacers for a while now, had a couple potential sources/deals fall through so I'm wondering if anyone else has any used ones for sale? Quote Link to comment Share on other sites More sharing options...
Darren-B Posted October 25, 2010 Share Posted October 25, 2010 Could you not just get the shims (halfrauds special) Quote Link to comment Share on other sites More sharing options...
km002916 Posted October 26, 2010 Author Share Posted October 26, 2010 Wouldn't be able to go up to 10mm as I'd need longer studs, that's the major problem as I can get 10mm spacers second hand but cant find longer studs. Halfrauds ones aren'tt hubcentric either so I'd be reluctant to go any more than 3mm which I don't think would be enough. Quote Link to comment Share on other sites More sharing options...
dyla350z Posted October 26, 2010 Share Posted October 26, 2010 Wouldn't be able to go up to 10mm as I'd need longer studs, that's the major problem as I can get 10mm spacers second hand but cant find longer studs. Halfrauds ones aren'tt hubcentric either so I'd be reluctant to go any more than 3mm which I don't think would be enough. Yes the shims are only 3mm,your better off going 15mm,mvtech do 15mm,good quality & only £60,the prob with 10mm on hubcentric is the bolt holding them on can only be 10mm or smaller(depth).thats lots of load through such a small nut,ive played about with spacers on standard rays & i found the best set up is 15mm fronts&20mm back or 15mm all round,anything bigger detracts the quality of the drive imo though does look good. Quote Link to comment Share on other sites More sharing options...
km002916 Posted October 26, 2010 Author Share Posted October 26, 2010 I'm running aftermarket 20" alloys and 15mm would deffo be too wide unfortunetally, the 10mms really seem to be the biggest pain,5mm or below and 15mm or above is easy. Looking like I might need to just bite the bullit and buy them new but at over £100 inc delivery it's a sore one for a tight wad like me. Quote Link to comment Share on other sites More sharing options...
dyla350z Posted October 26, 2010 Share Posted October 26, 2010 Try mvtech,i think they use a uk machinist & may be able to do the 10mm,i was impressed by the quality & price Quote Link to comment Share on other sites More sharing options...
km002916 Posted October 26, 2010 Author Share Posted October 26, 2010 Do you mean MW Tech? Already tried, I was their test dummy on the 10mms (test ones are not useable as they were not hubcentric) to see if longer studs were required and since giving them the feedback they've had no luck sourcing longer studs to offer a 10mm kit. Quote Link to comment Share on other sites More sharing options...
dyla350z Posted October 26, 2010 Share Posted October 26, 2010 Do you mean MW Tech? Already tried, I was their test dummy on the 10mms (test ones are not useable as they were not hubcentric) to see if longer studs were required and since giving them the feedback they've had no luck sourcing longer studs to offer a 10mm kit. Yes ment mvtech. Quote Link to comment Share on other sites More sharing options...
km002916 Posted December 10, 2010 Author Share Posted December 10, 2010 I'm still on the hunt for these Quote Link to comment Share on other sites More sharing options...
MWTech Posted December 11, 2010 Share Posted December 11, 2010 comon dyla, thats 3 times you have said mvtech, even after being corrected :D yeah, the 10mm wasnt hubcentric as it was a test to see if you needed longer studs which unfortunately had no luck sourcing. normally there would be a lip round the inside to keep it hub centered dyla covered the problem why there is no 10mm available from me, as it is, the 15mm spacers supplied already use a special adapted nut to sit flush inside the 15mm rather than the 20mm plus, anything less and i personally would have reason to be slightly unconfident in the nuts long term strength, they would be very thin and the Z is a pretty heavy car its a shame they cost so much for the ones your after, especially since the 15mm available here are £60 delivered Quote Link to comment Share on other sites More sharing options...
km002916 Posted December 14, 2010 Author Share Posted December 14, 2010 comon dyla, thats 3 times you have said mvtech, even after being corrected :D yeah, the 10mm wasnt hubcentric as it was a test to see if you needed longer studs which unfortunately had no luck sourcing. normally there would be a lip round the inside to keep it hub centered dyla covered the problem why there is no 10mm available from me, as it is, the 15mm spacers supplied already use a special adapted nut to sit flush inside the 15mm rather than the 20mm plus, anything less and i personally would have reason to be slightly unconfident in the nuts long term strength, they would be very thin and the Z is a pretty heavy car its a shame they cost so much for the ones your after, especially since the 15mm available here are £60 delivered Tell me about it, I seriously grudge paying soo much for something that will make so little difference but I keep looking at the car and just dont think it looks right with the front wheels recessed and the rears sitting flush. Quote Link to comment Share on other sites More sharing options...
