fto78 Posted October 5, 2006 Share Posted October 5, 2006 At the moment, I have the standard Bose system which came with the car (GT pack).. I want to totally replace everything, the headunit, the speakers, the amp and the sub. I am going to get a double din for it.. but one thing I am not too sure is.. what connector do I need to plug the existing 3 sockets to the new headunit and where can i source them? My plan is one four channel amp to power the front and rear speakers. and one 2 channel amp to power the sub. Do you think that would be enough to do the job? Many thanks from the ice expert! Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted October 5, 2006 Share Posted October 5, 2006 Morning. As far as connectors - if you have the Bose unit you will need the Autoleads PC2-77-4 (Micra 4 speaker Adapter). Once you use this the Bose amp will NOT be turned on First Off - Head units - Personally I would always Alpine - They do a double din if you really want to go for one - IVA-W200Rihttp://www.alpine-europe.com/content/english/a2467.det.IVA-W200Ri_DVD-CD-MP3-WMA--Receiver---Mobile-Media-Station.htm I would not bother with the rear speakers, in a car the size of the Z there really is no point in them. Save you money for a better amp and comps for the front. I would either go for a 2-way amp and a monoblock if you can afford to or a 4 way amp and bridge two channels for the sub. What to actually go for in terms of speakers / amps all comes down to money. You could spent £300 and get a very budget system, £600 and get a better one or £1000 and a really good one....etc In terms of subs are you looking to use the stock location? If so I would recommend either getting a box made up or sealing up the existing one properly using fibreglass etc. Quote Link to comment Share on other sites More sharing options...
H5 Posted October 5, 2006 Share Posted October 5, 2006 Morning. As far as connectors - if you have the Bose unit you will need the Autoleads PC2-77-4 (Micra 4 speaker Adapter). Once you use this the Bose amp will NOT be turned on First Off - Head units - Personally I would always Alpine - They do a double din if you really want to go for one - IVA-W200Rihttp://www.alpine-europe.com/content/english/a2467.det.IVA-W200Ri_DVD-CD-MP3-WMA--Receiver---Mobile-Media-Station.htm I would not bother with the rear speakers, in a car the size of the Z there really is no point in them. Save you money for a better amp and comps for the front. I would either go for a 2-way amp and a monoblock if you can afford to or a 4 way amp and bridge two channels for the sub. What to actually go for in terms of speakers / amps all comes down to money. You could spent £300 and get a very budget system, £600 and get a better one or £1000 and a really good one....etc In terms of subs are you looking to use the stock location? If so I would recommend either getting a box made up or sealing up the existing one properly using fibreglass etc. +1 And add that you should put 10% of budget aside for matching quality cabling (trust me it makes a difference) and at least Dynamat behind the front speakers. Quote Link to comment Share on other sites More sharing options...
fto78 Posted October 5, 2006 Author Share Posted October 5, 2006 Thanks for the advice.. Yes i am going fot that Alpine unit Quote Link to comment Share on other sites More sharing options...
