350zblack Posted October 12, 2010 Share Posted October 12, 2010 i have a uk spec 350z with the brembos, ive seen some alloys that have an offest of 35f and 35r, now i understand the standard 17" alloys have an offset of 30f 33r and they clear the brembos fine? what is the correct offset needed on the alloys to clear the brembos without the need for spacers? thanks Quote Link to comment Share on other sites More sharing options...
TADDY Posted October 12, 2010 Share Posted October 12, 2010 what size rims are they? you should just about clear on the fronts and the rears will be fine, tho imo a lower offset would be better as the wheels will sit really far inside the arches. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted October 12, 2010 Share Posted October 12, 2010 also dependant on spoke profile Quote Link to comment Share on other sites More sharing options...
350zblack Posted October 12, 2010 Author Share Posted October 12, 2010 what size rims are they? you should just about clear on the fronts and the rears will be fine, tho imo a lower offset would be better as the wheels will sit really far inside the arches. 19", 8.5 wide front 9.5 wide rears, and as said they are et35 ill probably see how/if they fit without spacers. then if needed to fit or for looks go for something minimal like the eibach 5-10mm ones? thanks Quote Link to comment Share on other sites More sharing options...
TADDY Posted October 12, 2010 Share Posted October 12, 2010 ive got 19 8.5 n 9.5 et 35 and cleared fine but as attack says it may also depend on the spoke desighn, what wheels are they? Quote Link to comment Share on other sites More sharing options...
