ZMANALEX Posted October 16, 2010 Share Posted October 16, 2010 Just taken it for the service, mentioned the oil problem...they rang me back and said theres oil all over the plugs and engine. They said it needs to be taken to a main dealer sharpish and they havent done the service! Ill be taking it to the Nissan garage in Portsmouth, not sure if its worth taking it somewhere else for a second opinion if anyone knows anywhere good? Simmo, let's just take a wee step back here: If the oil is on the electrode part of the spark plug then indeed you do have a serious problem. However, if it is a case that when they removed the plugs and the plug "stem" was oiled up then that is an easy fix as the cam box cover oil seals will be the issue. Alex. Quote Link to comment Share on other sites More sharing options...
Simmo Posted October 18, 2010 Author Share Posted October 18, 2010 Thanks for the advice again guys, booked into Nistech in Portsmouth Wednesday morning see what they reckon. Quote Link to comment Share on other sites More sharing options...
Simmo Posted October 20, 2010 Author Share Posted October 20, 2010 Just got the car back, they reckon the piston rings are knackered (technical term) so its burning the oil off ridiculously fast. Quoted me £1000+ for full repair but they believe its drivable as long as the oil is constantly checked. The staff are ex-Nissan, and they said that Nissan quote 1l oil per 100 miles driving as acceptable losses. I know this has been discussed before but I read on another site that fully synthetic oil will require topping up more often as it is less viscous and will be burnt off quicker, making non or part synthetic a better option for me? They also said that it will degrade the cat, thats not a problem atm as Im considering getting Abbey MS to change it anyways:). Any advice as to whether I should pay to get it fixed fully? Quote Link to comment Share on other sites More sharing options...
Darren-B Posted October 20, 2010 Share Posted October 20, 2010 Get it fixed sharpish before you properly break it Quote Link to comment Share on other sites More sharing options...
M13KYF Posted October 20, 2010 Share Posted October 20, 2010 +1 ask what abbey would charge but I would get it fixed. Quote Link to comment Share on other sites More sharing options...
dyla350z Posted October 20, 2010 Share Posted October 20, 2010 Ide consider a re-con engine or a low milage salvage engine,i will cost a min of 2k but they may strip yours down & find other problems,re-the oil ide ditch the 5-30 & put some semi syn 10-40 in, the fully syn will at the mo be to thin & p**s through the rings. Quote Link to comment Share on other sites More sharing options...
Simmo Posted October 20, 2010 Author Share Posted October 20, 2010 Yeh Ill ask them for a proper quote and get it done instead of new alloys I guess, definately better getting it fixed if I want to get it upgraded at some point. Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted October 20, 2010 Share Posted October 20, 2010 they said that Nissan quote 1l oil per 100 miles driving as acceptable losses. 1 liter per one hundred miles! So in a run from say Brighton to Aberdeen, you could completely run a 350Z dry and thats considered acceptable! I'd question that. Quote Link to comment Share on other sites More sharing options...
dyla350z Posted October 20, 2010 Share Posted October 20, 2010 Ask mark at abbey for his opinion,im no expert but like i said ide go for a salvage lump with low miles,you dont here about many major engine problems on the zeds,sounds like the engine may of had a hard life before you owned it. Quote Link to comment Share on other sites More sharing options...
Simmo Posted October 20, 2010 Author Share Posted October 20, 2010 Oops I meant 1l per 1000miles Going to run it with decent 10/40W semi synthetic see if it makes any difference before I start swapping engines I think, and maybe drive it a little more sensibly. Quote Link to comment Share on other sites More sharing options...
ChrisS Posted October 20, 2010 Share Posted October 20, 2010 Oops I meant 1l per 1000miles and you bagged the user name I was going to change too Quote Link to comment Share on other sites More sharing options...
