relentless Posted October 9, 2010 Share Posted October 9, 2010 hi all, The passenger side low beam isnt working on my 53 JDM Ive tried changing the bulb and changing the fuse but still no good. Now i thought this was odd - the bulb were both getting hot/warm but still not coming on (maybe the wrong polarity causing this?) Anyone ideas? Cheers Mark Quote Link to comment Share on other sites More sharing options...
Stew Posted October 9, 2010 Share Posted October 9, 2010 Does the car have HID lights or standard bulbs? If HID I'd suggest it could be the box of tricks attached to the underside of the light unit. Quote Link to comment Share on other sites More sharing options...
relentless Posted October 9, 2010 Author Share Posted October 9, 2010 the low beam is standard as far as i know. just 2 wires going straight into it. The high beam has a silver box on the back of it so im guessing thats xenon? it looks like this: Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 9, 2010 Share Posted October 9, 2010 Have you checked for any relays that might be in the circuit? Quote Link to comment Share on other sites More sharing options...
relentless Posted October 9, 2010 Author Share Posted October 9, 2010 errr, how would i do that? Do you know if theres polarity on the bulb? The "old" bulb has a creamy coloured mark in it btw...almost like its overheated or something. The filament is intact. Quote Link to comment Share on other sites More sharing options...
Zugara Posted October 9, 2010 Share Posted October 9, 2010 Do you have a Multimeter? If so you could check bulb for continuity.. or attach a battery and see if it lights up. I would assume the creamy colour is right near the filament? If so it would be the heat of the filament on the internal glass surface causing it. I would think that there is a relay somewhere in the fuse housing, yo uwould need to check the owners manual to see where they are located. ARE you SURE the fuse is ok? Quote Link to comment Share on other sites More sharing options...
Husky Posted October 9, 2010 Share Posted October 9, 2010 the bulb in the picture above is actually your high beam and the one with the silver box on the back is your dipped beam as mentioned, check the fuse first. but as you point out the bulb has a look to it of being blown, if that's so you may well need a new HID bulb. Also the problem could lie with the ballast which is attached to the underneath of the unit. check & replace: fuse bulb ballast in that order Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted October 9, 2010 Share Posted October 9, 2010 my money is on the ballast, which i just so happen to have a spare one of water can get in to them and then they die. Quote Link to comment Share on other sites More sharing options...
Stew Posted October 10, 2010 Share Posted October 10, 2010 For a test - remove the ballast and put it in the airing cupboard for a couple of days. Refit and see if it works..... Quote Link to comment Share on other sites More sharing options...
relentless Posted October 10, 2010 Author Share Posted October 10, 2010 right, its seems that i had an imbecile attack!! its actually the HID bulb that wasnt lighting up! has this blown - is the black/brown part normal? Can anyone confirm whether its a 4300k etc by the number on there? Cheers Quote Link to comment Share on other sites More sharing options...
relentless Posted October 10, 2010 Author Share Posted October 10, 2010 guess im gonna have to swap bulbs to be sure - and try the drying out ballast idea also. fuse ok as i swapped it with a known working one. cheers fellas for suggestions Quote Link to comment Share on other sites More sharing options...
relentless Posted October 10, 2010 Author Share Posted October 10, 2010 is it ok to connect HID bulb direct to battery to test? Quote Link to comment Share on other sites More sharing options...
Husky Posted October 10, 2010 Share Posted October 10, 2010 no you need the ballast mate Quote Link to comment Share on other sites More sharing options...
Stew Posted October 11, 2010 Share Posted October 11, 2010 I'd (personally) always replace bulbs in pairs. With HID though that can be pricey! Quote Link to comment Share on other sites More sharing options...
P15UL T Posted October 11, 2010 Share Posted October 11, 2010 Hi mate If possible swap the bulb from the othe side to see if it works in the light that the current one dosnt. If it works then your other bulb is goosed. If it dosnt work the tbd power pack at the bottom of the headlight may be faulty As with stu I would recommend changing bulbs in pairs to Make sure you get the same light and colour output I also have powerpacks for sale if you need them Cheers paul Quote Link to comment Share on other sites More sharing options...
relentless Posted October 11, 2010 Author Share Posted October 11, 2010 managed to source problem - quite simply the bulb has gone! So much forem lasting for a billion hours or whatever they suppsoed to last for..... Tried bulb from other light in ballast and working fine.....so just ordered a pair of new HIDs, went for 4300k as prefer range over colour. cheers all for your help. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted October 11, 2010 Share Posted October 11, 2010 i have spare bulbs as well you could have had for 20.00 original factory bulbs. Quote Link to comment Share on other sites More sharing options...
