E-drive electronic throttle controller
marshy167
Hey i have just bought the e-drive electronic throttle controller. I have wired it all, but i have no power to the unit - no display. Instead of sending it all back, can someone let me know the basic connections and where, to make sure that i have not missed somethig obvious...
Has anyone get one? Can anyone help?
Marshy167
I had the same problem with my one that I bought. I tried taking the pins out and putting them directing into the OBD connector - that didn't work either, so you may be wasting your time.
I returned it and got a replacement which worked first time.
I believe it to be very similar to the D1 spec module. I think i has the same basic connections.
My car is an 05 import, so it should work.
There is a spare blue wire which fits into the lighting circuit and opts reverse out of the throttle control. I have not put wired this in, will it still work?
I have taken the accelator connector out, put in the the e-drives connector and the other end goes into the spare socket on the right hand side under the fog and vdc switches.
I had an 05 too, I didn't connect the reversing wire in and it was fine.
  • 3 weeks later...
