trackpig Posted October 5, 2010 Share Posted October 5, 2010 Hi all, As my girlfriend uses the Z everyday to travel to work, I am thinking of fitting some winter tyres to my spare oem Touring style alloy wheels for use over the winter months. The standard set up on these wheels is 225/45/18 front and 245/45/18 rear. My question is- would there be any problem fitting 235/40/18 to front and rear? I dont think there would be be thought I'd ask on here first Cheers Quote Link to comment Share on other sites More sharing options...
Husky Posted October 5, 2010 Share Posted October 5, 2010 check the tyre calculators to see how much they are out by and post it up. if the tyres are out by even a little it can lead to unhappy traction control. obviously not a problem in the snow as its going to be off but the rest of the time will be very annoying. Quote Link to comment Share on other sites More sharing options...
trackpig Posted October 5, 2010 Author Share Posted October 5, 2010 http://www.alloywheels.com/tyrecalc.asp This calculator shows the tyres will be OK for width of the wheels, I was also concerned about any rubbing issues at the front on the Z specifically. Quote Link to comment Share on other sites More sharing options...
Husky Posted October 5, 2010 Share Posted October 5, 2010 rubbing on 235? ive got 265 on the front I believe part of the TC activation is based on the difference in wheel speed from front to back. The zed is meant to have a staggered set up which this will remove... personally i wouldn't do it, especially in winter but its your call. Quote Link to comment Share on other sites More sharing options...
trackpig Posted October 5, 2010 Author Share Posted October 5, 2010 arh... I see what you are saying with regards the TC and EBD Back to the drawing board then. Quote Link to comment Share on other sites More sharing options...
trackpig Posted October 5, 2010 Author Share Posted October 5, 2010 Ok, I think I have sorted the sizes out: 225/40's front and 245/40 rear This should keep the tyre sizes and tyre ratio very similar to standard and not give TC/EBD problems- any thoughts? The tyres below seem to a good compromise between winter performance and cost. http://ssl.delti.com/cgi-bin/rshop.pl?d ... sowigan=Wi http://ssl.delti.com/cgi-bin/rshop.pl?d ... sowigan=Wi Quote Link to comment Share on other sites More sharing options...
Husky Posted October 5, 2010 Share Posted October 5, 2010 nankangs in the dry and wet have a terrible reputation, BUT i dont know about that specific tyre, it may be really good. only way is to read up on the reviews. but, the sizes although matched front and back, are quite far off the standard size meaning gearing and speedo will be out. looks like the kumho ones are the cheapest for the correct sizes Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted October 5, 2010 Share Posted October 5, 2010 Why don't you want to put standard tyre sizes on ? Quote Link to comment Share on other sites More sharing options...
Husky Posted October 5, 2010 Share Posted October 5, 2010 the standard sizes push the budget up by 50 quid per tyre Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted October 5, 2010 Share Posted October 5, 2010 the standard sizes push the budget up by 50 quid per tyre well worth it IMO Quote Link to comment Share on other sites More sharing options...
Husky Posted October 5, 2010 Share Posted October 5, 2010 the standard sizes push the budget up by 50 quid per tyre well worth it IMO agreed Quote Link to comment Share on other sites More sharing options...
trackpig Posted October 5, 2010 Author Share Posted October 5, 2010 the standard sizes push the budget up by 50 quid per tyre well worth it IMO agreed Fair point but thats £200 less for fags and booze I think ill go for the 225/40 and 245/40 option. The speedo will over read so its not too much of a problem. Quote Link to comment Share on other sites More sharing options...
Husky Posted October 5, 2010 Share Posted October 5, 2010 fags booze and hookers for xmas it is Quote Link to comment Share on other sites More sharing options...
Greekman Posted October 5, 2010 Share Posted October 5, 2010 the standard sizes push the budget up by 50 quid per tyre well worth it IMO agreed Fair point but thats £200 less for fags and booze I think ill go for the 225/40 and 245/40 option. The speedo will over read so its not too much of a problem. i v run 40s on more than 4 sets of tyres. ps2s and 050As. my 888s are also 40 prof. never had an issue m8. expect the car to be a bit lower than on 45s tho. speedo shows 34 when actual speed is 30 according to my road angel pro. uniroyals have good reputation in the wet. ps2s very very good and so are the 050As. i know there are proper winter tyres out there as well but havent got a clue about them. Quote Link to comment Share on other sites More sharing options...
trackpig Posted October 5, 2010 Author Share Posted October 5, 2010 i v run 40s on more than 4 sets of tyres. never had an issue m8. Is that 225/40 front and 245/40 rear? Or did you run completly the same tyre size on each corner? Cheers Quote Link to comment Share on other sites More sharing options...
Greekman Posted October 5, 2010 Share Posted October 5, 2010 i v run 40s on more than 4 sets of tyres. never had an issue m8. Is that 225/40 front and 245/40 rear? Or did you run completly the same tyre size on each corner? Cheers it has to be 225/40/18 front 245/40/18 rear. the price difference between 40 and 45 is stupid i know. and i v run these sizes with and without spacers and from average to catch the cat's eyes drop too. Quote Link to comment Share on other sites More sharing options...
