Guest prescience Posted January 18, 2006 Share Posted January 18, 2006 350Z Fluids Recommendation Data (information provided by oilman) I've been reading a few oil threads here and thought this data may be of use. It comes from a proprietory database to which I subscribe and the data contained in it comes from OEM's. Nissan, 350 Z, 350 Z / Fairlady Z, 2004- [Preliminary Info] Manufacturer: Nissan Motors Co., Ltd., Tokyo, Japan Drive type: r.w.d. Cylinder capacity: 3498 cc Power output: 280 HP/206 kW at 6200 RPM Engine VQ35DE Petrol, 4-stroke, 6 cylinder, V, 4 valves/cil., liquid cooled Cylinder capacity: 3498 cc Power output: 280 HP /206 kW at 6200 RPM Capacity: 4.7 liter Overhaul capacity: 5.4 liter Filter capacity: 0.3 liter Use: normal - OEM recommendation Below 15 API: SL SAE 5W-30 Above -20 API:SL SAE 5W-40 Above -20 API: SL SAE 10W-30 Above -20 API: SL SAE 10W-40 Above -20 API: SL SAE 15W-40 Below 15 ILSAC GF-2 SAE 5W-30 Above -20 ILSAC GF-2 SAE 5W-40 Above -20 ILSAC GF-2 SAE 10W-30 Above -20 ILSAC GF-2 SAE 10W-40 Above -20 ILSAC GF-2 SAE 15W-40 ..... Transmission, manual, 6 speed Manual Capacity: 2.9 liter Gears forward: 6 Gears reverse: 1 Use: normal - OEM recommendation year-round API: GL-4 SAE 75W-85 ..... Differential, front, limited slip Capacity: 1.4 liter Use: normal - OEM recommendation year-round API: GL-5 LS SAE 80W-90 Use only limited slip hypoid gear oil which is approved for Nissan LSD. ..... Transmission, automatic Automatic Gears forward: 5 Gears reverse: 1 Use: normal - OEM recommendation year-round Special ATF, Nissan - OEM recommends Nissan Matic J ATF. ..... Hydraulic brakes/clutch system, ABS Use: normal - OEM recommendation year-round Brake fluid, DOT 3 - year-round Brake Fluid DOT 4+ - Never mix different types of fluids. ..... Power steering Capacity: 1 liter Use: normal - OEM recommendation year-round Dexron III - ..... Grease points/nipples Use: normal - OEM recommendation year-round Lithium base multipurpose grease NLGI No. 2 ..... Cooling system Capacity: 7.9 liter Reservoir: 0.8 liter Use: normal - OEM recommendation year-round Nissan Anti Freeze Coolant (L250) - ..... Link to comment Share on other sites More sharing options...
