Bedding in new tires....
slimjim
OK,
So after lots and lots of help from you all, I finally have some good tires on my back wheels!
So, how do I bed them in? Do I need to drive gently for a couple of hundred miles?
Do a 40-50 second burn out?
What do I have to do?
Cheers peeps!
as above about 500 miles, depends on the tyre and how much release agent they use. toyos are pretty bad for it.
and don't do a burn out on new tyres, the rubber is heat sensitive and need a few heat cycles in them to be at their best then they are fine. if you burn out on fresh tyres it can make them not as effective as they could be.
I have recently had new Falkens all round and would agree with the 500 miles to bed in :thumbs:
The first 50 or so felt a bit slippery, but now its so much more grippy. Just take it gently, you will feel the difference after a few hundred miles :yahoo:
