jmk Posted September 21, 2010 Share Posted September 21, 2010 hey could someone give me a detailed explaination on how to remove the passanger door car from my Z the motors gone looking to change it.... thanks people Quote Link to comment Share on other sites More sharing options...
The Hoff Posted September 21, 2010 Share Posted September 21, 2010 1) Pop out the black trim behind the door opener, undo the screw behind that. 2) Pop off the silver trim (very carefully) on the door handle using a screwdriver or the like at the bottom and gently prise it out. Undo both screws you can now access at the top and bottom. Remove door handle. 3) Remove the elec window switch/arm rest trim, it just pops off by lifting up the back first. Disconnect the plug and remove the new screw you can now see. 4) Pull the door card from the door starting at the bottom left, its take some pulling pull will pop off bit by bit. Be carefull at the top right by the tweeter grill, you need to tilt the door up at the back to allow it to move out easily. 5) Job done. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted September 21, 2010 Share Posted September 21, 2010 http://www.350z-tech.com/zwiki/Tutorial:Front_Speaker_Installation There you go, strangely it was the first hit when I put '350z door card removal' into Google Quote Link to comment Share on other sites More sharing options...
jmk Posted September 21, 2010 Author Share Posted September 21, 2010 thanks guys for your quick response must tackle it l8r... Quote Link to comment Share on other sites More sharing options...
HaydnH Posted September 21, 2010 Share Posted September 21, 2010 There you go, strangely it was the first hit when I put '350z door card removal' into Google And you didn't use a "Let me Google that for you" link?? Was that so hard? Quote Link to comment Share on other sites More sharing options...
doctor austin Posted September 21, 2010 Share Posted September 21, 2010 Just done mine this evening took an hour .. the motor just needed the commutator cleaning..works brill now Quote Link to comment Share on other sites More sharing options...
