rtbiscuit Posted September 19, 2010 Share Posted September 19, 2010 This is something i was never really aware of when i had the zed as no one really spoke of it; so my guess is no one has really done it or thought of it. Since i've been over on S2KI.COM i've learnt a few things that might be useful for Zed owners. This is the latest thing i've found out. as winter approaches and the wet weather increases lots of S2K owners use a silicone grease and lube up all the seals. these are the seals around the softtop and where the window meets the roof. it helps to plump up the rubber keeps the rubber nurished and helps it do its job better. those who are struggling with leaky windows may find that this along with a window reset my help cure the problem as the windows seal the same on both cars. it will also prolong the life of the seals and make them more effective. i've just bought 2 14g tubs of super lube which should see me good for several years. hope this helps others Quote Link to comment Share on other sites More sharing options...
Roo Posted September 19, 2010 Share Posted September 19, 2010 Also repels water preventing ice forming sticking the rubber to the car. I used to use vasaline! Quote Link to comment Share on other sites More sharing options...
Will370z Posted September 19, 2010 Share Posted September 19, 2010 Excellent idea, thanks for the info. Where can I get hold of this stuff as I'm sure it will come in handy? Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted September 19, 2010 Share Posted September 19, 2010 Good info and this does work. I used to do this every winter on the troublesome T-top 300zx. Quote Link to comment Share on other sites More sharing options...
Greekman Posted September 19, 2010 Share Posted September 19, 2010 silicone spray once a week after a good scrub. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 19, 2010 Author Share Posted September 19, 2010 i bought this stuff http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT lads on the other site only tend to do it once a year, but no harm in being more frequent. others have said if your using the spray put it direct onto the cloth then rub in. only needs a thin film so 30g should last a very long time. doesn't have to be this stuff, any silicone grease will do stuff from diving shops is mena tto be good. Quote Link to comment Share on other sites More sharing options...
Will370z Posted September 19, 2010 Share Posted September 19, 2010 Cheers will order some asap. Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted September 19, 2010 Share Posted September 19, 2010 I've been using this. http://www.einszett.co.uk/Gummi-Pflege.php Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 19, 2010 Author Share Posted September 19, 2010 I've been using this. http://www.einszett.co.uk/Gummi-Pflege.php looks like good stuff, anything is a good idea. one of the big debates on the other side was should you use the honda reccomended shin-etsu grease. its now very hard to get hold of and very expensive. general consensus over there was any silicone grease will do, so why pay over the odds for shin-etsu. Quote Link to comment Share on other sites More sharing options...
bounty78 Posted September 19, 2010 Share Posted September 19, 2010 might get myself a pot of those silicone grease now that winter is coming. Never did know there is a solution for sticky door seals Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted September 19, 2010 Share Posted September 19, 2010 Also repels water preventing ice forming sticking the rubber to the car. I used to use vasaline! Vaseline sounds a bit risky. If it can deteriorate the rubber in JIMMY HATS not sure how it reacts to door seels Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 20, 2010 Author Share Posted September 20, 2010 Also repels water preventing ice forming sticking the rubber to the car. I used to use vasaline! Vaseline sounds a bit risky. If it can deteriorate the rubber in JIMMY HATS not sure how it reacts to door seels someone tried it on s2ki and it made the windows not shut properly. had to open the door to get them to shut properly Quote Link to comment Share on other sites More sharing options...
marzman Posted September 20, 2010 Share Posted September 20, 2010 Also repels water preventing ice forming sticking the rubber to the car. I used to use vasaline! Vaseline sounds a bit risky. If it can deteriorate the rubber in JIMMY HATS not sure how it reacts to door seels Quote Link to comment Share on other sites More sharing options...
Chris`I Posted September 20, 2010 Share Posted September 20, 2010 I've been using this. http://www.einszett.co.uk/Gummi-Pflege.php Do it right and use this. Stew pointed us all to it IIRC quite some time ago. Treat all my cars with it now, works a treat Quote Link to comment Share on other sites More sharing options...
Vik54 Posted September 20, 2010 Share Posted September 20, 2010 Chris! that's it out of stock now Quote Link to comment Share on other sites More sharing options...
Dblock Posted September 20, 2010 Share Posted September 20, 2010 Chris! that's it out of stock now eBay is usually the cheapest place to order it if your just ordering one thing Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 20, 2010 Author Share Posted September 20, 2010 do people want me to bulk order the super lube and sell out at cost price to save people a few pennies (this is not for profit; i am not trading) Quote Link to comment Share on other sites More sharing options...
Roo Posted September 20, 2010 Share Posted September 20, 2010 Fair point vasaline aint to good for other "rubber" - so I think you are probably right on the not too good for long term use... I was using on an old renault 5 GT "deathbox" so rubber seals deteriating were the last of my worries... the lack of safety features and crumple zone being more worrying! Now im off to pulse and cocktails to get some "door seal lubricant"..... Quote Link to comment Share on other sites More sharing options...
Will370z Posted September 21, 2010 Share Posted September 21, 2010 do people want me to bulk order the super lube and sell out at cost price to save people a few pennies (this is not for profit; i am not trading) I'd be up for some, sounds good. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 21, 2010 Author Share Posted September 21, 2010 mine arrived today, if there are 10 people or at least enough people who want to share 10 pots i'll order a job lot. i bought 2 as they are only 14 g each Quote Link to comment Share on other sites More sharing options...
bounty78 Posted September 21, 2010 Share Posted September 21, 2010 like your avatar biscuit Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 21, 2010 Author Share Posted September 21, 2010 like your avatar biscuit thankyou i got bored of all the subtle digs at my new car, so i thought i would change my avatar to something subtle Quote Link to comment Share on other sites More sharing options...
kevlo Posted September 21, 2010 Share Posted September 21, 2010 do people want me to bulk order the super lube and sell out at cost price to save people a few pennies (this is not for profit; i am not trading) I'd be up for some, sounds good. i'd be up for some too please Quote Link to comment Share on other sites More sharing options...
Chris`I Posted September 21, 2010 Share Posted September 21, 2010 i got bored of all the subtle digs at my new car, so i thought i would change my avatar to something subtle Well if you would get yourself a hairdressers car. Plus you are probably on here more than the S2K forums Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 21, 2010 Author Share Posted September 21, 2010 i got bored of all the subtle digs at my new car, so i thought i would change my avatar to something subtle Well if you would get yourself a hairdressers car. Plus you are probably on here more than the S2K forums i'm on both equally, but more happens here in the green room Quote Link to comment Share on other sites More sharing options...
