clutch problem?
Drycounty
I have a strange noise coming from what seems to be the clutch. In 1st and 2nd, depressing the clutch causes a loud clunking/vibrating noise. It also sometimes happens when i just let off the throttle in 1st and 2nd. On tick over if you press the clutch it sounds very very noisy. I've been searching the web and have lots of different explanations.
If anyone can diagnose the problem as dumpton park nissan can't determin what the issue actually is!
Any help will be gratefully appreciated.
its normal mate, just a characteristic of the car, check others at a nissan dealer. mines does the same
No m8. he said if you press the clutch...if you press the clutch it disappears.
sounds like thrust bearing. but others will comment soon with more accurate comments.
ah mate nice one yeah that sounds a bit weird, usually its the otherway about.
