rothers2901 Posted September 10, 2010 Posted September 10, 2010 Hi all. I have a slight problem and hoping that someone out there will be able to shead some light. I recently posted my intention to follow other Z owners by having the cast plenum polished. We i have just had it back from the polisher (looks Great) put everythingback on and fired the Z back to life after 3 weeks. She fire up first time and is running just fine the problem is that the Malfunction indicator light has stayed on. It's constant and not blinking. I have tried to re-set the accelorator position and the throtle control actuator as per the manual but it's still on. ANY IDEAS PLEASE Quote
rothers2901 Posted September 10, 2010 Author Posted September 10, 2010 Sorry but how do you find out what code it is? Quote
UNABASHED Posted September 10, 2010 Posted September 10, 2010 either hook it up to a code reader od do the manual accelerator pressing method Quote
rothers2901 Posted September 10, 2010 Author Posted September 10, 2010 Tried the manual way but nothing happens. A friend is bringing a code reader thanks Quote
M13KYF Posted September 10, 2010 Posted September 10, 2010 Have you tried to reset the ECU, can be found in the guides section Quote
rothers2901 Posted September 11, 2010 Author Posted September 11, 2010 Found it now off to play Quote
