Light weight wheels, interesting findings.
rtbiscuit
icame across this else where, its an extract from a recent fast ford magazine that had some interesting information and tests done on light weight wheels. Anyway, I thought a few of you may be interested in this...
They have a very good test in this month's edition. They have a tuned Fiesta ST that is running 215bhp. They changed the standard ST wheels for Team Dynamic Pro Race 1.2s which are altogether 12kg lighter. They mention that 12kg unsprung weight is equivalent to around 48kg weight saving from the chassis. They undertook 4 tests -
Test 1 - Braking. 60-0mph and 100-0mph
Test 2 - Handing. A timed lap around a circuit
Test 3 - Standing start acceleration to 60mph
Test 4 - In gear acceleration. 30-80mph
Results - All tests were performed 3 or 4 times and the times were then averaged. Results were gained using a Racelogic Performance Box.
Test 1 - Before 60-0 = 3.2s Before 100-0 = 5.3s G = 0.97
After 60-0 = 3.0s After 100-0 = 4.8s G = 1.07
Test 2 - Before = 1:28.6 After 1:24.3
Test 3 - Before 0-60 = 6.9s Before 0-100 = 17.8s Quarter mile = 15.7 @ 94mph
After 0-60 = 7.4s After 0-100 = 18.0s Quarter mile = 15.9 @ 94mph
Test 4 - Before 30-80 = 8.8s After 30-80 = 8.3s
I'm sure you'll agree there is some intersting results there. Quite a difference on the timed circuit. They said they thought the 0-60 times were down on the standard wheels as there was less mass for the engine to turn, therefore the wheels tended to spin more when applying the accelerator.
Hope this is of some use to some people!
interested on how the tyres were matched?
:thumbs: me too, they'd need to have swapped the rubber there and then to something they wanted to test it with. either way weight saving is the way to go, kinda goes without saying really. therefore not replacing current setup with anything else for the moement then rays.
my guess is that if it was to be an accurate test then they must have run the same tyres on both wheels i.e. brand and model of tyre. without the original article i don't know.
Interesting they make the 0-60 time significantly worse but improve all the other numbers :shrug:
yep less weight to move so the car lights them up easier
That's really interesting, makes me glad I've never changed my rays!
I've also wondered if having bigger wheels affects speed/handling as you have more rubber down but more weight where you don't really want it.
there are lighter wheels than the rays out there. all have an effect and change the characterisitcs.
Was this the Redline test? Stav mentioned there were some pretty impressive results. Light wheels are the way forward unless you are a 0-60 legend then. :thumbs:
i think it was a fast ford issue from this month. must admit i'm not a fan of 0-60 drag racing, wheres the fun in going fast in a straight line, any moron can do that. going fast round a corner now thats a whole different ball game.
I recently put a set of BST carbon fibre wheels on my motorcycle...you'll really notice all of the benefits above and some! I wouldn't have got the same performance gain if I'd have spent the same money on engine tuning.
on a bike you'll feel the difference due to the gyroscopic effect of the rotating wheel as well ........ a lighter front wheel will need less effort (force) to turn in the plane normal to the rotating plane of the wheel .... so the bike will feel more agile :dance:
:scare::thumbs:
had to check that out... and yeah still bleeding expensive! whats the weight difference on your bike on the tyres?
Price: £2,586.00 Including VAT at 17.5%
:scare: can get a turbo setup on the R6 for that mate! :blush:
Great post Rich, thanks for sharing :thumbs:
I'm going to edit the title too, hope you don't mind.
yeah no worries, i'm guessing it was a keying error; thats the problem with homer simpson hands :blush:
very true gyroscopic effect plays a big part like rotational mass, almost more so than unsprung and sprung weight
Unsprung weight is one thing, rotational mass is quite another.
Reducing rotational mass is the key one here because not only do you have to drag the mass of the component upto the speed of the car (as in it is part of the car), but you also have to spin it up to its rotational speed.
Hence you have to perform two sets of acceleration on it!
Of course, what we actually need to know is the angular momentum.
This will give you the energy used to spin up the component.
the higher your angular momentum, the more your gyroscopic effect.
Hence, the faster your heavy large diameter wheels spin, the more resistance they have to having their direction altered.
This can cause allsorts of issues with handling.
The Powerball works on gyroscopic forces and if you have ever had a go, you know how difficult it can be to manipulate when spinning.
If your an IT techie, pick up a hard drive when it's on, gently move it about and you can feel the gyro resisting/magnifying your movements (I AM NOT RESPONSIBLE FOR YOUR DATA LOSS IF YOU DO THIS AND DROP THE DRIVE smile.gif )
In addition, the engine, clutch, flywheel spinning will cause a yawing effect. Granted, not mega, but it's present and it's something to be minimised (can be quite a serious problem on motorbikes, not to mention Helicopters and radial engined aircraft!).
So when people go on about 19" wheels wrecking the handling, you now know why
one of the heaviest parts of the wheel is actually the tyre, i'm sure those of you who have light weight wheels will tell you, you could probably pick one alloy up with 1 finger, but add a tyre and its a whole different matter.
Hence why outboards are set off centreline on boats and why high powered dragsters twist the chassis on take off
A%20hard%20launch%20for%20the%20amazing%20USA-1%20Camaro.%20Photo%20by%20Dave%20Milcarek.jpg
i'm guessing in the weight of the wheel andlind is addin gthe air as well.
from another site i got this list of wheel and tyre weights,
Tyre weights of AD08s from here http://www.yokohamatire.com/tires/spec. ... OVA%20AD08
Tyres
Fronts
16" 21lb
17" 22lb
Rears
16" 22.9lb
17" 25.5lb
Wheels
Front
16" Cast 17.5lb
16" BBS 13.3lb
17" '04 17.6lb
Rear
16" Cast 18.6lb
16" BBS 14.3lb
17" '04 20.5lb
Total
Front
16" Cast 38.5lb (17.5kg)
16" BBS 34.3lb (15.6kg)
17" '04 39.6lb (18.0kg)
Rear
16" Cast 41.5lb (18.8kg)
16" BBS 37.2lb (16.9kg)
17" '04 46.0lb (20.9kg)
someone elses research, but goes to show how much the tyres weigh
Tyres
Fronts
16" 21lb
17" 22lb
Rears
16" 22.9lb
17" 25.5lb
Wheels
Front
16" Cast 17.5lb
16" BBS 13.3lb
17" '04 17.6lb
Rear
16" Cast 18.6lb
16" BBS 14.3lb
17" '04 20.5lb
Total
Front
Rear
low profile so :teeth:
best to put nitrogen in your tyres. wont make them lighter, but they won't be as reactive to heat. and so the pressures won't change as the heat does.
great for tracking B)
why keep the radius the same?
if your rolling radius is way out, so your speedo will be as well. you'll be travelling a further distance per revolution compared to what the speedo will be reading.
or it works in reverse if you go smaller.
