jollyranchers Posted September 5, 2010 Share Posted September 5, 2010 Guys just wondering how easy is it to change the exhaust on the Z from the Y pipe back using a trolley jack etc ? Is there any DIY guides / tips anywhere i couldnt find any ? Have any of you purchased any low ramps from anywhere recently for using with the Z to get better access for an exhaust change? cheers Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 5, 2010 Share Posted September 5, 2010 decent axle stands are a better idea. Quote Link to comment Share on other sites More sharing options...
Husky Posted September 5, 2010 Share Posted September 5, 2010 not so much of a guide but an emotional response viewtopic.php?f=9&t=37294&start=0&hilit=exhaust+struggle Quote Link to comment Share on other sites More sharing options...
jollyranchers Posted September 6, 2010 Author Share Posted September 6, 2010 Thanks Husky ! sounds like im in for a real treat Quote Link to comment Share on other sites More sharing options...
marzman Posted September 6, 2010 Share Posted September 6, 2010 In theory its a piece of...cake, but in practice, all your bolts will be seized on and you'll probably have to use heat to get them off. When i had mine done i took it to my mate at the garage, and it took him an hour to get it off, and ended up burning every but off...! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 7, 2010 Share Posted September 7, 2010 +1 had a issue woth mine when I had the nismo put on. The OEM had one of the bolts solid. Got some heat on it to budge it. TDI North did this for me. They are based in warrington so not far away from you. Reasonable rates too http://www.tdi-north.com/ Quote Link to comment Share on other sites More sharing options...
jollyranchers Posted October 4, 2010 Author Share Posted October 4, 2010 Ok so my new exhaust is due to arrive later on in the week I got plus gas,Breaker bar , Blow torch already etc My question is if i take that stability type guard off would it be easier just splitting the midpipe to y pipe and try and take the back box and mid pipe together ? How do people find clearance using axle stands is there enough room to comfortably get in ?! Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted October 4, 2010 Share Posted October 4, 2010 My question is if i take that stability type guard off would it be easier just splitting the midpipe to y pipe and try and take the back box and mid pipe together ? How do people find clearance using axle stands is there enough room to comfortably get in ?! I think that depends how you current exhaust have been put on the hangers. It should be possible to get the back box and mid section out in one go if everything is can slide one way off the hangers once you have the y-pipe disconnected. When I had my new one put on the old the rear silencer and mid pipe came off in one go.. still together. If you have decent axle stands they you should be ok..some bits might be a bit awkward. Quote Link to comment Share on other sites More sharing options...
Husky Posted October 5, 2010 Share Posted October 5, 2010 i'd give the bolts a go first and if they round then try the whole lot in one. it may be a bit like those metal puzzles you get in a christmas cracker though. Quote Link to comment Share on other sites More sharing options...
jollyranchers Posted October 5, 2010 Author Share Posted October 5, 2010 Ha ha cant wait !..... Found a couple more guides on the net http://crackaddict.com/~flynn/howtos/in ... .howto.htm http://www.350z-tech.com/zwiki/Tutorial ... st_Install Quote Link to comment Share on other sites More sharing options...
martinmac Posted October 5, 2010 Share Posted October 5, 2010 My mate has considerable strength and he had to give it some stick to remove the old one. I was less than a year old too. Quote Link to comment Share on other sites More sharing options...
doctor austin Posted October 5, 2010 Share Posted October 5, 2010 I changed my system by driving it up on several concrete slabes on just one side and made myself comfy together with a grinder and ground off any stubbern bolts. The tip that helped me was to lubricate the mounting rubbers in order to pull off the barbed type mountings and also to refit. Quote Link to comment Share on other sites More sharing options...
ChrisS Posted October 5, 2010 Share Posted October 5, 2010 A little expensive,but I have been assured they work on rounded nuts. http://www.screwfix.com/prods/96028/Van ... emover-Set Quote Link to comment Share on other sites More sharing options...
HaydnH Posted October 9, 2010 Share Posted October 9, 2010 A little expensive,but I have been assured they work on rounded nuts.http://www.screwfix.com/prods/96028/Van ... emover-Set I love these - I'm not sure why they're not used more instead of regular sockets as they push on the flat sides of the bolt (stronger) instead of the points (weaker). Quote Link to comment Share on other sites More sharing options...
