Androo Posted September 4, 2010 Share Posted September 4, 2010 Hey guys, Just got my K1 through the post, couple of questions.. * Can you use gasket paste as a replacement to gaskets? * - Can you use the OEM nuts ones to fit? Cheers Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted September 4, 2010 Share Posted September 4, 2010 Doubt you'll get the original bolts off in one piece Quote Link to comment Share on other sites More sharing options...
chippychip123 Posted September 4, 2010 Share Posted September 4, 2010 OEM are studs so you won't be able to use them. You might be able to reuse the y pipe to mid pipe gasket but you will need two new ones for the back cans. Did you get the exhaust new? Quote Link to comment Share on other sites More sharing options...
Androo Posted September 5, 2010 Author Share Posted September 5, 2010 No, i bought it from a member on here.... Well im off to the local tyre & exhaust fitters in the morning to get it sorted - they will have the bolts no doubt, but the only thing i wondered about was whether i could get away with gasket paste/silicone rather than the gaskets? From what i can see where the centre section joins the y pipe there is no trace of a gasket being used there (the putty was used by the looks of it) Does anyone else just ditch the gaskets and use the other sealing method? Cheers guys Quote Link to comment Share on other sites More sharing options...
350 Russ Posted September 5, 2010 Share Posted September 5, 2010 i used gaskets on my k2 that i got from zmanalex and worked a treat! i bought an exhaust off of a member aswell with no gaskets Quote Link to comment Share on other sites More sharing options...
Androo Posted September 5, 2010 Author Share Posted September 5, 2010 Thanks Russ - only problem being i am too impatient Ive heard of people fitting before without gaskets, and should be fine - i cant see there being any/much flex down that part, so lets hope for the best eh? I'll let you guys know tomorrow what the fitting centre says..... Quote Link to comment Share on other sites More sharing options...
Androo Posted September 6, 2010 Author Share Posted September 6, 2010 WELL in a massive turn of events, it appears im not bloody allowed a noisey exhaust. Parents and neighbours have had enough after 5 years. I need my own gaff. that blows. Quote Link to comment Share on other sites More sharing options...
350 Russ Posted September 6, 2010 Share Posted September 6, 2010 that sucks! get a k2 then, not too noisey just nicely tuned Quote Link to comment Share on other sites More sharing options...
mattbowey Posted September 6, 2010 Share Posted September 6, 2010 i just used gasket paste on mine and the nuts on mine had been replaced and i got some from neilp when i bought it so they werent a prob for me. had no bother with it so i guess the paste stuff is doing its job. got a mechanic next door so is pretty handy for doing stuff on the car. Quote Link to comment Share on other sites More sharing options...
Androo Posted September 7, 2010 Author Share Posted September 7, 2010 thanks guys - local exhaust centre also confirmed that paste is absolutely fine! Yeah, its the one of the major downsides to still living at home...boooo. Maybe i can push with the K2 Previously had Hyundai's (2.0 and 2.7v6) totally decat and boy that was annoying i bet... having the windows shake for 20 mins on the cold mornings whilst i de-iced the car Quote Link to comment Share on other sites More sharing options...
