bakseedaa Posted August 31, 2010 Share Posted August 31, 2010 Hi I am using the Megs G220 DA polisher on black edition 370. I use Poorboys black hole polish with the 3m blue finishing pad. I then use the dodo juice supernatural wax. Am i using the correct pad for thepolish and is there a soft buffing pad for the removal of the wax? thanks Quote Link to comment Share on other sites More sharing options...
Envy Valeting Posted August 31, 2010 Share Posted August 31, 2010 Your pad choice should be fine for the black hole, though you could also try the 3m black glossing pad as its even softer. To remove the wax you need to use a towel such as https://www.envyvaleting.com/products_info.asp?id=165 Quote Link to comment Share on other sites More sharing options...
bakseedaa Posted September 1, 2010 Author Share Posted September 1, 2010 Thanks for that i will give the black pads a go. I do have the buffing towels i was just seeing if there was anything to help a lazy git out Quote Link to comment Share on other sites More sharing options...
