lomoto Posted September 26, 2006 Share Posted September 26, 2006 Good results then Tim Yes . might bring it to the Wales Run out see who has the loudest How was the test conducted mate??? Is it technical or just a case of popping the meter out the window nothing technical mate , just switch it on and point it at the exhaust pipe got to be simple for me to use it Tim, you know as well as I do that there are prescribed distances for conducting noise tests - inverse sqaure law and all that. Did you follow them during the above? Oh yes to the letter Dorian Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 26, 2006 Share Posted September 26, 2006 Good results then Tim Yes . might bring it to the Wales Run out see who has the loudest How was the test conducted mate??? Is it technical or just a case of popping the meter out the window nothing technical mate , just switch it on and point it at the exhaust pipe got to be simple for me to use it Tim, you know as well as I do that there are prescribed distances for conducting noise tests - inverse sqaure law and all that. Did you follow them during the above? Oh yes to the letter Dorian Quote Link to comment Share on other sites More sharing options...
lomoto Posted September 26, 2006 Share Posted September 26, 2006 yeah good idea bring it with you mate! will prob be you or even Jacko his DC zorst is loud Yes I've heard Jacko's it is very loud Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted September 26, 2006 Share Posted September 26, 2006 Good results then Tim Yes . might bring it to the Wales Run out see who has the loudest How was the test conducted mate??? Is it technical or just a case of popping the meter out the window nothing technical mate , just switch it on and point it at the exhaust pipe got to be simple for me to use it Tim, you know as well as I do that there are prescribed distances for conducting noise tests - inverse sqaure law and all that. Did you follow them during the above? Oh yes to the letter Dorian I knew the answer - but it gives all the more credence to the results. Next time, blow your own trumpet Quote Link to comment Share on other sites More sharing options...
Removed Posted September 26, 2006 Share Posted September 26, 2006 surely it'll still give enough info for a ballpark figure anyway (and still in Tim's case help out with the MOT of the bikes) Quote Link to comment Share on other sites More sharing options...
Rish Posted September 27, 2006 Share Posted September 27, 2006 115 dB at 6000 rpm. Quote Link to comment Share on other sites More sharing options...
Wa_Wa Posted October 1, 2006 Share Posted October 1, 2006 I don't know what the noise limits are at other circuits, but Goodwood is quite strict because of complaints from local residents. They have two days - a 98dB one and a 105dB one - but I'm not sure how many revs the readings are taken at - I have a feeling it's 4000. I remember Hagar has done a track day at Goodwood. If you're out there Hagar, are you able to shed any light on this? Quote Link to comment Share on other sites More sharing options...
