s1xtyn1n3 Posted August 24, 2010 Share Posted August 24, 2010 My airbag warning light started flashing the other day and after doing the reset procedure, it disappeared. It later started flashing again a few days later. I've now noticed that after resetting the warning light, it comes on once a passenger has got out. I'm guessing there's probably something lose or strange going on under my passenger seat but having looked, I couldn't see anything obvious and I'm not really sure what to look for. Does anyone know what it is before I resort to a trip to the stealership? Quote Link to comment Share on other sites More sharing options...
350zStephen Posted August 24, 2010 Share Posted August 24, 2010 Very common fault mate, search youtube for "350z airbag". its an easy fix Quote Link to comment Share on other sites More sharing options...
s1xtyn1n3 Posted August 24, 2010 Author Share Posted August 24, 2010 I can't find anything there besides how to reset it, which I have already done, but it comes back every time a passenger gets out of the seat?? Quote Link to comment Share on other sites More sharing options...
350zStephen Posted August 24, 2010 Share Posted August 24, 2010 Sorry dude, i'm being silly tonight - never fully read your post as I was playing FIFA Can't be much more help. Cheers Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 24, 2010 Share Posted August 24, 2010 check connectors under the seat and re seat them. If still no jot the loom may be trapped in the seat itself and has become damaged. It will require a bit of soldering tot fix. Should cost around £40. A good auto electrician will be able to do it and cheaper than the dealers. Access to the loom in the rear of the seat is easy as the covers unzip. I had this issue in the back of the seat. Quote Link to comment Share on other sites More sharing options...
s1xtyn1n3 Posted August 25, 2010 Author Share Posted August 25, 2010 Thanks! I've had another look under the seat, tightened up all the connectors and made sure the seat wasn't catching anything. I tried to test it last night but as there was only one of me, so not sure if it's fixed or not yet - will find out later if i need to give someone a lift home from work Quote Link to comment Share on other sites More sharing options...
s1xtyn1n3 Posted August 27, 2010 Author Share Posted August 27, 2010 All looks to be fine now - reseating the connectors apparently solved the problem. Cheers Quote Link to comment Share on other sites More sharing options...
