djrm Posted August 23, 2010 Share Posted August 23, 2010 Hi there people I am removing my plenum and just wanted some advice on it. Is there anything I should watch out for? Anything I can mess up?? Thanks Ryan Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 23, 2010 Share Posted August 23, 2010 Hi there people I am removing my plenum and just wanted some advice on it. Is there anything I should watch out for? Anything I can mess up?? Thanks Ryan Very straight forward Ryan, Just be careful when refitting that you do not nip anything between the flanges. Quote Link to comment Share on other sites More sharing options...
Zugara Posted August 23, 2010 Share Posted August 23, 2010 Hi there people I am removing my plenum and just wanted some advice on it. Is there anything I should watch out for? Anything I can mess up?? Thanks Ryan Very straight forward Ryan, Just be careful when refitting that you do not nip anything between the flanges. Yes like the oil filler rubber collar. Like i did.... Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 23, 2010 Share Posted August 23, 2010 and makle sure nothing is in the way or not seated properly or you could crack the plenum like husky did when he fitted a plenum spacer. Quote Link to comment Share on other sites More sharing options...
Husky Posted August 23, 2010 Share Posted August 23, 2010 and makle sure nothing is in the way or not seated properly or you could crack the plenum like husky did when he fitted a plenum spacer. Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 Haha ok then so most care must be taken when replacing.... Noted.... I have taken almost all of the screws out now, just wanted to clear up a few things with a couple of pics, just need to be sure about this before I tear it open and mess it all up lol... This pipe on the left, can I just disconnect? Is it just an air pipe? Do I need to remove the air control unit (I'm assuming that's what it is) Or does it come off with the plenum? Do I need to remove these 6 bolts from the top? Thanks I know I'm a newbie to this, just want to be sure about it though! Ryan Quote Link to comment Share on other sites More sharing options...
andlid Posted August 23, 2010 Share Posted August 23, 2010 download a manual mate! ill see if i have my old one and ill pm u Quote Link to comment Share on other sites More sharing options...
Husky Posted August 23, 2010 Share Posted August 23, 2010 yes remove hose, just a breather yes remove 6 bolts they hold it on dont remove throttle body unless you need to but disconnect the connector (electrical) Quote Link to comment Share on other sites More sharing options...
andlid Posted August 23, 2010 Share Posted August 23, 2010 Here you go! READ FIRST! http://www.350z-tech.com/zwiki/Plenum_S ... stallation Quote Link to comment Share on other sites More sharing options...
andlid Posted August 23, 2010 Share Posted August 23, 2010 yes remove hose, just a breatheryes remove 6 bolts they hold it on dont remove throttle body unless you need to but disconnect the connector (electrical) ...dotn break it... Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 Right, Husky, you say don't remove the throttle body but andlid, your link says do remove it? Which should I do?? The problem is that the allen bolts holding the throttle body on are extremely tight... All I have is allen keys and they don't have enough leverage... Is it best to go out and get an allen wrench or would some Wd40 help the situation??? Thanks guys Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 Starting to think maybe I shouldn't bother lol... Seems like an awful lot can go wrong??? Quote Link to comment Share on other sites More sharing options...
Husky Posted August 23, 2010 Share Posted August 23, 2010 depends on what your doing it for Quote Link to comment Share on other sites More sharing options...
Husky Posted August 23, 2010 Share Posted August 23, 2010 Starting to think maybe I shouldn't bother lol... Seems like an awful lot can go wrong??? no its pretty simple Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 Starting to think maybe I shouldn't bother lol... Seems like an awful lot can go wrong??? no its pretty simple Yeah, to someone who knows what they are doing I am removing it simply to polish it up!! Quote Link to comment Share on other sites More sharing options...
Androo Posted August 23, 2010 Share Posted August 23, 2010 A good soak of plusgas or wd-40 overnight will help to loosen if off - just remember - dont yank the allen key, gently squeeze/pull it or you could end up rounding things off then it'll get fun Also make sure nothing falls down there whilst the plenum is off.... Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 Lol I might be a newbie but I'm not that dumb... The allen key is for the ones holding the throttle body on.... Il be careful to not let anything drop too... Quote Link to comment Share on other sites More sharing options...
TADDY Posted August 23, 2010 Share Posted August 23, 2010 where abouts are you? it dosen't matter wether you take off the throtle body or not its up to you. Quote Link to comment Share on other sites More sharing options...
Androo Posted August 23, 2010 Share Posted August 23, 2010 yeah, sorry, im the dumb one there - must learn to read beforehand.... updated my post to less idiotic comments Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 where abouts are you? it dosen't matter wether you take off the throtle body or not its up to you. OK thanks I am in Essex dude... Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 yeah, sorry, im the dumb one there - must learn to read beforehand.... updated my post to less idiotic comments Haha no worries man, thanks for the advice... I know I am asking a lot of stupid questions but I would rather know too much than nothing! Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted August 23, 2010 Share Posted August 23, 2010 here's the intallation instructions. Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 here's the intallation instructions. Thanks... I will have a good read! Quote Link to comment Share on other sites More sharing options...
TADDY Posted August 23, 2010 Share Posted August 23, 2010 where abouts are you? it dosen't matter wether you take off the throtle body or not its up to you. OK thanks I am in Essex dude... ahh too far for me to come and help you ive got to take mine off tomoz so could do you a step by step guide if you can wait? but with the looks of it ur almost there anyway, get yourself the allen keys that are on a handle bit like a swiss army knife and that will give you the leverage Quote Link to comment Share on other sites More sharing options...
djrm Posted August 23, 2010 Author Share Posted August 23, 2010 where abouts are you? it dosen't matter wether you take off the throtle body or not its up to you. OK thanks I am in Essex dude... ahh too far for me to come and help you ive got to take mine off tomoz so could do you a step by step guide if you can wait? but with the looks of it ur almost there anyway, get yourself the allen keys that are on a handle bit like a swiss army knife and that will give you the leverage Thanks mate, I am going to have a crack at it again tomorrow, going to put some WD40 on them overnight to help and get allen keys with more leverage and reach but if you want to take some pics and get them on here.... feel free!! Quote Link to comment Share on other sites More sharing options...
