Installing a Husband
kObi
Dear Tech Support,
Last year I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed a distinct slow down in overall system performance, particularly in the flower and jewelry applications, which operated flawlessly under Boyfriend 5.0.
In addition, Husband 1.0 uninstalled many other valuable programs, such as: Romance 9.5 and Personal Attention 6.5,
and then installed undesirable programs such as:
NBA 5.0,
NFL 3.0 and
Golf Clubs 4.1.
Also, Conversation 8.0 no longer runs and Housecleaning 2. 6 simply crashes the system.
Please note that I have tried running Nagging 5.3 to fix these problems, but to no avail.
What can I do?
Signed,
Desperate.
DEAR DESPERATE ,
First, keep in mind,
Boyfriend 5.0 is an Entertainment Package, while
Husband 1.0 is an operating system.
Please enter command: ithoughtyoulovedme.html and try to download Tears 6.2 and do not forget to install the Guilt 3.0 update.
If that application works as designed, Husband 1.0 should then automatically run the applications Jewelry 2.0 and Flowers 3.5.
However, remember, overuse of the above application can cause Husband 1.0 to default to Grumpy Silence 2.5 , Happy Hour 7.0 or Beer 6.1.
Please note that Beer 6. 1 is a very bad program that will download the Farting and Snoring Loudly Beta.
Whatever you do, DO NOT under any circumstances install Mother-In-Law 1.0 (it runs a virus in the background that will eventually seize control of all your system resources.)
In addition, please do not attempt to reinstall the Boyfriend 5.0 program, These are unsupported applications and will crash Husband 1.0.
In summary, Husband 1.0 is a great program, but it does have limited memory and cannot learn new applications quickly. You might consider buying additional software to improve memory and performance. We recommend Cooking 3.0 and Hot Lingerie 7.7.
Good Luck!
Tech Support
...and why not this too
and this one too, slightly the same but i burst out laughing at the '10 new ways...'
Been awhile since i was last on so i'll start off by posting my usual rubbish here.
Subject:
Warning, Trojan Horse Software!
QUESTION
Last year I upgraded from Girlfriend 7.0 to Wife 1.0 and noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this phenomenon was included in the product brochure. In addition, Wife 1.0 installs itself into all other programs and launches during system initialization, where it monitors all other system activity. Applications such as Pokernight 10.3, Drunken Boys Night 2.5 and Saturday Football 5.0 no longer run, crashing the system whenever selected. I cannot seem to keep Wife 1.0 in the background while attempting to run some of my other favorite applications. I am thinking about going back to Girlfriend 7.0, but the uninstall does not work on this
program. Can you please help me! Thanks, Joe
REPLY
Dear Joe:
This is a very common problem men complain about but is mostly due to a primary misconception. Many people upgrade from Girlfriend 7.0 to Wife 1.0 with the idea that Wife 1.0 is merely a UTILITIES & ENTERTAINMENT program.
Wife 1.0 is an OPERATING SYSTEM and designed by its creator to run everything. It is unlikely you would be able to purge Wife 1.0 and still convert back to Girlfriend 7.0. Hidden operating files within your system would cause Girlfriend 7.0 to emulate Wife 1.0 so nothing is gained. It is impossible to uninstall, delete or purge the program files from the system once installed. You cannot go back to Girlfriend 7.0 because Wife 1.0 is not designed to do this. Some have tried to install Girlfriend 8.0 or Wife 2.0 but end up with more problems than the original system. Look in your manual under "Warnings-Alimony/Child Support".
I recommend you keep Wife 1.0 and just deal with the situation. Having Wife 1.0 installed myself, I might also suggest you read the entire section regarding General Partnership Faults (GPFs). You must assume all responsibility for faults and problems that might occur, regardless of their cause. The best course of action will be to enter the command C:\APOLOGIZE.
In any case avoid excessive use of the Esc key because ultimately you will have to give the APOLOGIZE command before the operating system will return to normal. The system will run smoothly as long as you take the blame for all the GPFs.
Wife 1.0 is a great program, but VERY high maintenance. Consider buying additional software to improve the performance of Wife 1.0. I recommend Flowers 2.1 and Chocolates 5.0. Do not, under any circumstances, install Secretary With Short Skirt 3.3. This is not a supported application for Wife 1.0 and is likely to cause irreversible damage to the operating system.
Best of luck, Tech Support
