Demolition49 Posted August 17, 2010 Share Posted August 17, 2010 The click begins at 15950 miles! At the moment it only happens when moving off or changing from reverse .... only somtimes and then it doesnt happen when driving etc... its only and 06 with low miles, got an extended warrantee, should i book her in? The brakes are intermittently squeaky when moving and when brakes applied it stops, probably need to grease up the pads? Somtimes when steering there is a tiny squeak - belts need changing maybe? So should i book her in for some warrantee work and if so where is the best place in london to get my Z done? And whats the best things to tell them? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted August 17, 2010 Share Posted August 17, 2010 The click begins at 15950 miles! At the moment it only happens when moving off or changing from reverse .... only somtimes and then it doesnt happen when driving etc... its only and 06 with low miles, got an extended warrantee, should i book her in? That sounds like "Clicky Axle" issue See viewtopic.php?f=35&t=15928&hilit=clicky+axle The brakes are intermittently squeaky when moving and when brakes applied it stops, probably need to grease up the pads? Yeah, prolly need some coppergrease on the pad backing plates. Quote Link to comment Share on other sites More sharing options...
Demolition49 Posted August 17, 2010 Author Share Posted August 17, 2010 The click begins at 15950 miles! At the moment it only happens when moving off or changing from reverse .... only somtimes and then it doesnt happen when driving etc... its only and 06 with low miles, got an extended warrantee, should i book her in? That sounds like "Clicky Axle" issue See viewtopic.php?f=35&t=15928&hilit=clicky+axle The brakes are intermittently squeaky when moving and when brakes applied it stops, probably need to grease up the pads? Yeah, prolly need some coppergrease on the pad backing plates. Yeah i thought that much... but what should i tell nissan and where is the best place to go in london to get her done because i dont want the clicky axle problem to come back, id like the uprated axle... Quote Link to comment Share on other sites More sharing options...
AlexZ Posted August 17, 2010 Share Posted August 17, 2010 You may find both the noises are related mate...The pads sometime knock on the calipers if theres no copper grease etc on them. This normally happens when you take up drive or select reverse. I would grease the rear surface of the pads first and clean all mateing faces... Alex Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted August 17, 2010 Share Posted August 17, 2010 can not comment on the click noise but i had a squeeky steering and it sounded as if the power steering belt was slipping. Upon checking the power streering levels i found it to be below the recommended limit. A top up cured the problem. rothers2901 Quote Link to comment Share on other sites More sharing options...
Demolition49 Posted August 19, 2010 Author Share Posted August 19, 2010 hmm if i have an 06 facelift then it cant be clicky axle? http://www.350z-tech.com/zwiki/TSB_04-0 ... _Rear_Axle So is it drop links or fuel damper? only happens when i change from like reverse to first and vice versa. and once again anybody know good dealer in london to get the work done? Quote Link to comment Share on other sites More sharing options...
