KyleR Posted April 23, 2012 Share Posted April 23, 2012 I'm going to give this a little bump as i'd be interested to know the same as Dicky. Quote Link to comment Share on other sites More sharing options...
sparky370z Posted April 23, 2012 Share Posted April 23, 2012 when you "bake" the light its loosens up all of the glue. this means u have to pull apart the light cluster. there will be glue residue everywhere. once you have separated the lens and the back, there is a red lens that has to be removed. this is a pain really. then you should have a clear lens unit. once back on the car install a LED red lamp that i got from Ebay. you can usually only buy them in pairs. http://www.ebay.co.uk/itm/2X-Red-T10-19 ... 43ae09cb51 think these are the ones. i have had no problems with mine at all and did this mod about 2 years ago. Quote Link to comment Share on other sites More sharing options...
richt Posted April 23, 2012 Share Posted April 23, 2012 Haven’t noticed this little project before, which looks great by the way. What do you do once the unit is opened? Is there a red internal reflector you have to remove, then replace it with a red led ? and how do you reseal the unit again once finished?? Sorry to be a pain but Id like to have a go at this one. Once you've pulled out the red reflector the glue should still be sticky, simply push it all back together. I then ran some clear silicone round it all just to be sure. Get it done, it looks so much better. Quote Link to comment Share on other sites More sharing options...
Dicky Posted April 25, 2012 Share Posted April 25, 2012 Thanks for the info all Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 25, 2012 Share Posted April 25, 2012 Or do it properly and buy some crystal clear ones of US eBay for about £90 If a job is worth doing...... Quote Link to comment Share on other sites More sharing options...
