P15UL T Posted August 5, 2010 Share Posted August 5, 2010 Hi folks, i have got my car back from the body shop and on my way home i noticed that none of my switches on the drivers door are working, mirrors, windows etc does anyone know what fuse i should be looking for to check ? i have removed the switch panel and the harness are all in place thanks for any help Paul Quote Link to comment Share on other sites More sharing options...
H5 Posted August 5, 2010 Share Posted August 5, 2010 Does the passenger window work properly? ie drop when opens, window switch works? They are on the same loop AFAIK so it could be a dodgy switch pack on the drivers door.... Quote Link to comment Share on other sites More sharing options...
Ian Posted August 5, 2010 Share Posted August 5, 2010 Have you got lights on the speedo? When I blew the fuse for that it took out some of the door electrics. Its a 10amp fuse in the footwell (Can't remember which one though) oh, and Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 just went to try the passenger side switch and it went down but when i tried to put it up ...nothing...my missus is giving me the evils as were leaving for the isle of man tomorrow and could really be doing with everything working .... Quote Link to comment Share on other sites More sharing options...
Husky Posted August 5, 2010 Share Posted August 5, 2010 heres the power windows Power is supplied at all times through 40A fusible link (letter F , located in the fuse and fusible link box) to BCM terminal 7. through BCM terminal 28 to power window main switch terminal 1. to power window sub-switch terminal 10. With ignition switch in ON or START position, power is supplied through 10A fuse [No.1, located in the fuse block (J/B)] to BCM terminal 35. through BCM terminal 29 to power window main switch terminal 10. Ground is supplied at all times to BCM terminal 8 through body grounds E17, E43 and F152. to power window main switch terminal 15 through body grounds M30 and M66. to power window sub-switch terminal 11 through body grounds M30 and M66. Quote Link to comment Share on other sites More sharing options...
H5 Posted August 5, 2010 Share Posted August 5, 2010 Although I fear your switch pack has gone bang. The drivers side one is what controls both windows AFAIK. My passenger window has fallen out of love with the drivers side - it goes down each time I open the window but never goes back up. Luckily the switch works. Try the window reset procedure Paul (if you have / can get the door skin off quickly enough)..... Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 lol, in english please....where abouts is that fuse box, at the battery of in the drivers footwell ? Quote Link to comment Share on other sites More sharing options...
Madmarky Posted August 5, 2010 Share Posted August 5, 2010 I bet its the door iso not fully connected, had something similar with mine a while back when fitting the doors, could be a bent pin in there also so take it apart and check it out Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 Although I fear your switch pack has gone bang. The drivers side one is what controls both windows AFAIK. My passenger window has fallen out of love with the drivers side - it goes down each time I open the window but never goes back up. Luckily the switch works. Try the window reset procedure Paul (if you have / can get the door skin off quickly enough)..... i will pop the door card off and try the reset procedure,,,anyone got a link to it ? Quote Link to comment Share on other sites More sharing options...
Husky Posted August 5, 2010 Share Posted August 5, 2010 sorry that the one in the driver foot well Quote Link to comment Share on other sites More sharing options...
H5 Posted August 5, 2010 Share Posted August 5, 2010 I would do the following things 1. Check Marky's point above on the connections 2. Window reset procedure (I will put a link up in a second) 3. Check the fuse (put this last as if the passenger window went down then power is probably there) Quote Link to comment Share on other sites More sharing options...
H5 Posted August 5, 2010 Share Posted August 5, 2010 viewtopic.php?f=35&t=141 Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 just noticed another few gremlins, when the door is open i get an audible beeping ? i think it was there before but definetly sounds different/louder but if you push in the rear window heater button (left hand one of the 3 dials) it goes off ??? all lights on the dash and centre console are working as normal Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 another, drivers door isnt locking when pressing the keyfob...... dont think a window reset will work as i dont have power to move the glass ?? Quote Link to comment Share on other sites More sharing options...
350 Russ Posted August 5, 2010 Share Posted August 5, 2010 Maybe a bad earth somewhere Quote Link to comment Share on other sites More sharing options...
Cragus Posted August 5, 2010 Share Posted August 5, 2010 Any luck with this mate? Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 not yet, just going to try and find the fuse box to have a look, dismantled the drivers door switches and theres no bad pins think the mirror switches are working , pretty sure they werent earlier ???WTF Paul the frustrated ... Quote Link to comment Share on other sites More sharing options...
Cragus Posted August 5, 2010 Share Posted August 5, 2010 If I can help by holding a flashlight let me know Good luck Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 yeah currently having to hold it myself in the pitch black,,,,,,, no window operations on both doors (passenger will go down from passenger side switch but not back up ) no locking on the drivers doors Quote Link to comment Share on other sites More sharing options...
Cragus Posted August 5, 2010 Share Posted August 5, 2010 Say the word if you want me to shoot over and help in some way. Technically I will be useless but I can hold a light When you have finished get a quick pic up. I want to see it in one piece again Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 im FOOOKED,,,,,,i need the windows and door locks to work by 6am tomorrow or the holidays cancelled !!!!! were can a bad earth be ???? that would be causeing just the switches to be effected ? Quote Link to comment Share on other sites More sharing options...
Husky Posted August 5, 2010 Share Posted August 5, 2010 have you checked the fuses? Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 5, 2010 Author Share Posted August 5, 2010 have you checked the fuses? i lloked through them all with a torch and them seems ok, not sure which is the window or door switches though mirror controls only work on the drivers side and there is a beep from inside the cabin when operating them which is weird ??? must be an earth but where i dont know Quote Link to comment Share on other sites More sharing options...
350 Russ Posted August 5, 2010 Share Posted August 5, 2010 Could be anywhere, my dads lancia had one after having the engine out, it wouldn't idle occasionally and when it didn't idle the windows wouldn't work, he had to put it into a specialist and it was a bad earth in the abs system somewhere, I don't see this getting sorted tonight sorry to say mate Quote Link to comment Share on other sites More sharing options...
P15UL T Posted August 6, 2010 Author Share Posted August 6, 2010 sorted , as seen here : viewtopic.php?f=10&t=39737&start=15 Quote Link to comment Share on other sites More sharing options...
