Roadster ventilated seats on a Coupe
Removed
Across the pond they manged this as well....
"Ok so I finally tackled this swap of my seats. The seats fit perfect in the coupe and the bolt pattern is exactly the same as the roadster. The only thing that does not work is the option to tilt the seat up or down on the passenger side but the ZR has this option. The coupe as you know has a quick manual release handle to tilt the passenger seat up or down. When we took out the ZR seats we had to tilt the seat forward and forgot to tilt them back down to remove the bolts on the rear of the seat. As of now I do not have any way to tilt the passenger seat back down other than taking the seat out and reconnecting it to the ZR and then using the power tilt to straighten the seat out. The seats are a little more difficult to remove and replace due to the headrest not being able to remove from the seat. We kept the electrical box under the ZR but maybe that is what I may need to use the power tilt back operation or maybe the proper harness to use the power option ( JASON any ideas on this ). Overall the hardest part was just reconnecting the wire harnesses back the way they came and comparing the differences from both wiring harnesses..."
