captint Posted September 15, 2006 Share Posted September 15, 2006 Ok, so my JWT PC was installed by my myself and the man mavis, sounds great with the Kinetix Cats. My problem is now something is vibrating when I go over 5000 revs ( which is more often than not). Its coming from the boot, quite annoying, not my axle's clicking as they are being done on monday, it's a real high pitched buzzing vibration, and no I haven't been shopping at Ann summers Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 15, 2006 Share Posted September 15, 2006 Can't see any relation with the pop charger causing such a weird noise... Anymore clues??? How's she ticking over??? Quote Link to comment Share on other sites More sharing options...
H5 Posted September 15, 2006 Share Posted September 15, 2006 Unrelated to the JWT Popcharger, but boot catch? Quote Link to comment Share on other sites More sharing options...
captint Posted September 15, 2006 Author Share Posted September 15, 2006 Ticking over fine, no engine problems, oil's fine, its something internally behind me, not in me it'self, but in the car, perhaps the rear brace Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 15, 2006 Share Posted September 15, 2006 Radio on or off???? It's not the noisy amp thing is it???? Quote Link to comment Share on other sites More sharing options...
captint Posted September 15, 2006 Author Share Posted September 15, 2006 Radio off, it has do be something loose of something rattling around? Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 15, 2006 Share Posted September 15, 2006 Radio off, it has do be something loose of something rattling around? you said a "high pitched buzzing vibration"... try removing things from the boot including the mini tonneau Quote Link to comment Share on other sites More sharing options...
captint Posted September 15, 2006 Author Share Posted September 15, 2006 Is the mini Tonneau the small flap under the window Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 15, 2006 Share Posted September 15, 2006 Is the mini Tonneau the small flap under the window Correct mine efing vibrates Quote Link to comment Share on other sites More sharing options...
captint Posted September 15, 2006 Author Share Posted September 15, 2006 Nice one Liam, I think thats the burstard, have you any Blue Peter hints how to stop it Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 15, 2006 Share Posted September 15, 2006 Nice one Liam, I think thats the burstard, have you any Blue Peter hints how to stop it Undo the 2 retaining lugs either side, it comes straight off. Take it for a spin and make sure it's that first... Not sure off a cure, let me know if you find one Quote Link to comment Share on other sites More sharing options...
Sarnie Posted September 15, 2006 Share Posted September 15, 2006 Nice one Liam, I think thats the burstard, have you any Blue Peter hints how to stop it DOUBLE SIDED TAPE Quote Link to comment Share on other sites More sharing options...
captint Posted September 15, 2006 Author Share Posted September 15, 2006 I was actually think blue tack Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 15, 2006 Share Posted September 15, 2006 I was actually think blue tack Does your boot open and close properly??? Possibly do that penny thing with the struts, may also help Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted September 15, 2006 Share Posted September 15, 2006 I would say there are 4 possibilities for this noise 1. As mentioned above and you try fixing by applying a small amount of grease to the locating lugs 2. The top of the rear strut brace. Remove all the trim (pull sensibly but firmly to remove), and you will a satin liner underneath, lift that up and you should see a locating lug in the centre - cut it off, it serves no purpose 3. The top of the rear strut brace. Remove all the trim (pull sensibly but firmly to remove), pack in some additional felt, or wadding and replace 4. The manual boot release just below the rear strut brace, you'll just need to see why this is buzzing (if it is) and adjust Quote Link to comment Share on other sites More sharing options...
captint Posted September 15, 2006 Author Share Posted September 15, 2006 Great, good advice as usual chaps, there goes my Saturday!! Quote Link to comment Share on other sites More sharing options...
Stew Posted September 15, 2006 Share Posted September 15, 2006 Just think of all the fun you're going to have blasting about trying to get it to rattle! Quote Link to comment Share on other sites More sharing options...
captint Posted September 15, 2006 Author Share Posted September 15, 2006 True, plus with my JWT PC it sounds awesome now, I am just waiting for the performance gain to drop off, it really does feel faster Quote Link to comment Share on other sites More sharing options...
captint Posted September 17, 2006 Author Share Posted September 17, 2006 Problem sorted I hope, I took the silver fitting off of the rear strut brace, and pulled out the filling, took out the node thingy and packed it with felt. It seems to have gone, so cheers for the advice. Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted September 17, 2006 Share Posted September 17, 2006 Quote Link to comment Share on other sites More sharing options...
