Tricky-Ricky Posted July 25, 2010 Share Posted July 25, 2010 Has anyone got a JDM ECU Pinout diagram with wire colours if possible, as it might be closer to my JDM 350GT Skyline than the US infinity G35 and US 350Z manuals that i have, as nothing seems to match up or is not what its supposed to be. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 25, 2010 Share Posted July 25, 2010 This may help. The image of the ECU pin module has not copied so I can email it over if you wish. Pinout Pin Label Desc 1 GND ECM Ground 2 O2HFL Heated Oxygen Sensor 1 Bank 2 Heater 3 VMOT Throttle Control Motor Relay 4 MOTOR2 Throttle Control Motor (Close) 5 MOTOR1 Throttle Control Motor (Open) 6 02HRL Heated Oxygen Sensor 2 Bank 2 Heater 7 8 9 10 C-IVC (L) Intake Valve TIming Control Solenoid Valve Bank 2 11 C-IVC ® Intake Valve TIming Control Solenoid Valve Bank 1 12 PS PRES Power Steering Pressure Sensor 13 POS Crankshaft Position Sensor 14 PHASE LH CMP, Camshaft Position Sensor Bank 2 15 KNK Knock Sensor Signal 16 02SFR Heated Oxygen Sensor 1 Bank 2 Signal 17 18 19 20 21 INJ#5 Injector 5 22 INJ#3 Injector 3 23 INJ#1 Injector 1 24 02HFR Heated Oxygen Sensor 1 Bank 1 Heater 25 02HRR Heated Oxygen Sensor 2 Bank 1 Heater 26 27 28 29 30 31 32 FTPRS EVAP Control System Pressure Sensor Signal 33 PHASE RH CMP, Camshaft Position Sensor Bank 1 34 35 36 37 38 39 40 INJ#6 Injector 6 41 INJ#4 Injector 4 42 INJ#2 Injector 2 43 44 45 EVAP EVAP Canister Purge Control Solenoid Valve 46 47 AVCC2 TPS Sensor 1/2 Power Suppy 5V 48 AVCC PU Sensors Power Supply (EVAP Control System Pressure Sensor) 5V 49 AVCC PDPRES Refrigerant Pressure Sensor Voltage 5V 50 TPS1 Throttle Position Sensor 1 (0-5V) 51 QA+ Mass Airflow Sensor Signal 52 53 54 55 02SRL Heated Oxygen Sensor 2 Bank 2 Signal 56 57 58 59 60 IGN#5 Ignition #5 61 IGN#3 Ignition #3 62 IGN#1 Ignition #1 63 64 65 66 GND-A2 Sensor Ground (TPS Sensors 1/2) 67 GND-A Sensor Ground (MAF, IAT, PS Pres, EVAP Pres, ECT, ASCD, Refrig) 68 AVCC PS PRES Sensors Power Supply (PS Pressure, EVAP Pressure) 5V 69 TPS2 Throttle Position Sensor 2 (5-0V) 70 PDPRES Refrigerant Pressure Sensor 71 72 73 TW ECT, Engine Coolant Temperature Sensor Signal 74 O2SRR Heated Oxygen Sensor 2 Bank 1 Signal 75 76 77 78 GND-O2 Heated Oxygen Sensor 1/2 Bank 1/2 Ground 79 IGN#6 Ignition #6 80 IGN#4 Ignition #4 81 IGN#2 Ignition #2 82 GND-A Accelerator Pedal Position Sensor1 GND 83 GND-A2 Accelerator Pedal Position Sensor2 GND 84 85 86 CAN-L 87 88 89 90 ACVV Sensor Power Supply (Accelerator Pedal Position Sensor 1) 5V 91 ACVV2 Sensor Power Supply (Accelerator Pedal Position Sensor 2) 5V 92 93 94 CAN-H 95 96 97 98 APS2 Accelerator Pedal Position Sensor 2 Signal 99 ASCDSW ASCD (Steering Wheel Mounted) Switch (Automatic Speed Control) 100 101 BRAKE Stop Lamp Switch 102 NEUT Park/Neutral Switch (In Gear = BATT) 103 104 MOTRLY Throttle Control Motor Relay 105 106 APS1 Accelerator Pedal Position Sensor 1 Signal 107 108 BNCSW ASCD Brake Switch - Brake and Clutch Switch Input for Cruise Shutoff 109 IGN SW Ignition Switch (IGN = BATT) 110 111 SSOFF Self Shut-off Relay 112 113 FPR Fuel Pump Relay 114 115 GND ECM Ground 116 GND ECM Ground 117 CDCV EVAP Canister Vent Control Valve 118 119 VB Power Supply for ECM (IGN = BATT) 120 VB Power Supply for ECM (IGN = BATT) 121 BATT Power Supply for ECM (Always = BATT) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 25, 2010 Author Share Posted July 25, 2010 Thanks Alex, the only differences to the manuals i have are pins 34 and 35 which are supposed to be IAT and O2 signal for no1 bank 1 (not confirmed this yet, but the IAT is actually behaving like the coolant temp sensor so i guess it is on mine. 50 is not TPS on mine wrong value, and i don't have 51, but have 52 which is the right colour for the MFA but again wrong value, and i am guessing pin 73 is probably my IAT I also tried to use 62 for RPM but the LM-2 wont see it? the JDM 350GT ECU is obviously completely different I really don't want to have to go through it all with a meter Quote Link to comment Share on other sites More sharing options...
