kcw1556 Posted July 25, 2010 Share Posted July 25, 2010 hi guys, not been on the sit for a while been busy at work. just wondered if any of you have had a similar problem with your 350z's IE: engine pinking under acceleration. been using shell optimax and BP ultimat at every fill up, but the problem still exists, any ideas guy's thanx. Quote Link to comment Share on other sites More sharing options...
Neilp Posted July 25, 2010 Share Posted July 25, 2010 Can u describe in detail what is happening? Quote Link to comment Share on other sites More sharing options...
Zugara Posted July 25, 2010 Share Posted July 25, 2010 Had same on mine did ecu reset nd put highflow filter, problem sorted Quote Link to comment Share on other sites More sharing options...
kcw1556 Posted July 25, 2010 Author Share Posted July 25, 2010 Can u describe in detail what is happening? When driving along then suddenly boot it/give it some gas, its pinking, however it don't do it from cold or whilst its on choke, as soon as it warms up the problem starts, really annoying. Tried BP ultimate, Shell Optimax still no good. I think we are being stiffed at the fuel pumps? Seems we are paying for premium fuel and getting @*!#. Quote Link to comment Share on other sites More sharing options...
kcw1556 Posted July 25, 2010 Author Share Posted July 25, 2010 Had same on mine did ecu reset nd put highflow filter, problem sorted I might try that m8, how long did it take to do it? and how much was the cost, so I have a rough idea what I will be paying. Quote Link to comment Share on other sites More sharing options...
Zugara Posted July 25, 2010 Share Posted July 25, 2010 Told you what too do, Replace panel filter with high flow. Reset the ECU. Problem solved. I have the exact same on mine, if you "search" you will find it.... Quote Link to comment Share on other sites More sharing options...
kcw1556 Posted July 25, 2010 Author Share Posted July 25, 2010 Told you what too do, Replace panel filter with high flow. Reset the ECU. Problem solved. I have the exact same on mine, if you "search" you will find it.... Ok m8 will try that. Thanx 4 the info. Quote Link to comment Share on other sites More sharing options...
