get12 Posted September 14, 2006 Share Posted September 14, 2006 Hi, As you know, Nissan are exchanging corrosion damaged Rays, however I am being told by dealer that they will not replace kerb damaged wheels! I have no reason to doubt the dealer (Marshalls) as they are good, but has anyone had dealings with Nissan UK customer services, who did do a replacement on corrosion damaged AND kerbed rays so that I can prove that there is a precedent, or maybe you know of a someone or a dealer that has had them replaced with kerb damage? Regards G Quote Link to comment Share on other sites More sharing options...
Removed Posted September 14, 2006 Share Posted September 14, 2006 get it refurbed on the kerbed part, leave the corrosion @ get them done under warranty? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 14, 2006 Share Posted September 14, 2006 It was stated on here by a member that Nissan were no longer replacing Rays under warranty but just re-furbing them now Quote Link to comment Share on other sites More sharing options...
get12 Posted September 14, 2006 Author Share Posted September 14, 2006 get it refurbed on the kerbed part, leave the corrosion @ get them done under warranty? I had considered it but looking for a precedent first of all to hit Nissan CS with first. I am also concerned that as one of the wheels is badly kerb damaged (flattened the lip considerably), even if it was repaired there will still be a flat spot showing - also if I am doing that then I might as well get the whole wheel stripped and re-coated no!? G Quote Link to comment Share on other sites More sharing options...
get12 Posted September 14, 2006 Author Share Posted September 14, 2006 It was stated on here by a member that Nissan were no longer replacing Rays under warranty but just re-furbing them now Yeah that was me I think. The garage sends the pics off to Nissan, Nissan authorise and send another refurbed wheel out from someone els who has had the same problem (8 week lead time). My garage is saying that as someone else will ultimately be getting my wheels as refurbs Nissan can not be expected to repair kerb damage as well as corrosion. Quote Link to comment Share on other sites More sharing options...
get12 Posted September 14, 2006 Author Share Posted September 14, 2006 ....anyone got Nissan's customer service number? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 14, 2006 Share Posted September 14, 2006 check out F.A.Q's section its in there Quote Link to comment Share on other sites More sharing options...
H5 Posted September 14, 2006 Share Posted September 14, 2006 Let me know how you get on get12? I've got exactly the same, kerbed by previous oowner (not badly) but definitely corroding.... Quote Link to comment Share on other sites More sharing options...
get12 Posted September 14, 2006 Author Share Posted September 14, 2006 Let me know how you get on get12? I've got exactly the same, kerbed by previous oowner (not badly) but definitely corroding.... Just spoken to Nissan customer services - prognosis not good! Without speaking to Nissan's warranty department for a definite answer, CS was telling me that if the garage was telling me that kerbed corrosion damaged wheels are not being repaired then it is likely that they have had past experience of the warranty department refusing to replace kerbed wheels. Knowing that my garage is already dealing with 3 claims for corroded wheels then I suspect that what they are telling me is correct. I will just have to make do with the rear near-side being replaced! G Quote Link to comment Share on other sites More sharing options...
flavius1 Posted September 15, 2006 Share Posted September 15, 2006 does the corrosion look like the wheel has a cloudy appearance? two of my rays are like this Quote Link to comment Share on other sites More sharing options...
get12 Posted September 15, 2006 Author Share Posted September 15, 2006 does the corrosion look like the wheel has a cloudy appearance? two of my rays are like this I'm not sure what you mean by 'cloudy', but you can spot the corrosion easily as it appears bubbly-mine has rust spots on them as well. Quote Link to comment Share on other sites More sharing options...
headbanger Posted September 15, 2006 Share Posted September 15, 2006 I've got the same problem. Glyn Hopkins took photos about two weeks ago and I'm still waiting. There's quite a bit of a post over on http://forums.DELETED.com/inde ... l=bubbling if you're interested. Cheers Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted September 15, 2006 Share Posted September 15, 2006 Its a shocking attitude from CS. If the corrosion is from the curbing I agree you should not be replaced but if the spokes are corroding and the lips is curbed it should make no difference as it would not affect the spokes Quote Link to comment Share on other sites More sharing options...
H5 Posted September 16, 2006 Share Posted September 16, 2006 Its a shocking attitude from CS. If the corrosion is from the curbing I agree you should not be replaced but if the spokes are corroding and the lips is curbed it should make no difference as it would not affect the spokes Which is exactly my position. Watchdog?! Quote Link to comment Share on other sites More sharing options...
Mathys Posted September 16, 2006 Share Posted September 16, 2006 Good luck with Nissan on getting them replaced. Will be hard. Get12, you avatar is annoying!!!! Quote Link to comment Share on other sites More sharing options...
get12 Posted September 16, 2006 Author Share Posted September 16, 2006 Good luck with Nissan on getting them replaced. Will be hard. Get12, you avatar is annoying!!!! first time anyone's mentioned that! I moved it over from the OC's site - perhaps it's time to change it......???!!! Quote Link to comment Share on other sites More sharing options...
get12 Posted September 16, 2006 Author Share Posted September 16, 2006 Its a shocking attitude from CS. If the corrosion is from the curbing I agree you should not be replaced but if the spokes are corroding and the lips is curbed it should make no difference as it would not affect the spokes Which is exactly my position. Watchdog?! ....perhaps it's time for me to call Consumer Direct next week...... Quote Link to comment Share on other sites More sharing options...
H5 Posted September 16, 2006 Share Posted September 16, 2006 Checked mine today when cleaning it. Have non kerbed wheels corroding too so if they change one, I'll be arguing all the way to court about the kerbed one......! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 17, 2006 Share Posted September 17, 2006 they no longer change them H5. They just refurb them Quote Link to comment Share on other sites More sharing options...
H5 Posted September 17, 2006 Share Posted September 17, 2006 they no longer change them H5. They just refurb them My bad, meant refurb. Same sentiment, can't see them having a leg to stand on. Quote Link to comment Share on other sites More sharing options...
get12 Posted September 17, 2006 Author Share Posted September 17, 2006 Good luck with Nissan on getting them replaced. Will be hard. Get12, you avatar is annoying!!!! yeah yeah yeah! Quote Link to comment Share on other sites More sharing options...
get12 Posted September 20, 2006 Author Share Posted September 20, 2006 Just got an email back from Consumer Direct: Many thanks for your recent e-mail concerning your Nissan vehicle. I certainly understand your frustration. With regards to your warranty, you would be legally bound by whatever Terms & Conditions are stipulated, therefore I would initially advise you to read through the terms & Conditions which you have agreed. Moving on very slightly, you would have statutory rights as a consumer with whomever you pay your money to. All goods sold must comply with the Sale of Goods Act 1979 (as amended). This states all goods must be fit for purpose, and also satisfactory quality. Under this heading fall the sub-headings of reasonable durability and freedom from defects. Goods must also be As Described, which is also stipulated in the Sale of Goods Act 1979. From the information you have supplied it would appear that your goods may breach the above act, and if so then you are indeed entitled to redress. The remedies which are available to you include a repair, or a like-for-like replacement, and this would be whichever is more economical for the trader to provide. If the repair would mean that you would receive betterment, then it may be considered reasonable that you pay a proportion of the repair cost. So, what I take away from this is that Nissan should offer to share repair costs, which I would be happy with - as long as it is not over £50-£60 per wheel as that is the price I can get it done for from ChipsAway etc!!! Anyway - I have spoken to Marshalls and they are going to put forward my claim again to the Nissan warranty department - I should know on Tuesday next week where this is going. I suggest that everybody else that have the same problems as me start making enquiries - strength in numbers:) Graham Quote Link to comment Share on other sites More sharing options...
H5 Posted September 20, 2006 Share Posted September 20, 2006 Nice one, good luck! Quote Link to comment Share on other sites More sharing options...
headbanger Posted September 20, 2006 Share Posted September 20, 2006 That's excellent info... Cheers Quote Link to comment Share on other sites More sharing options...
