Thedancingmexican Posted July 21, 2010 Share Posted July 21, 2010 Hay guys, I'm new to the forums and this my first post so if it's in the wrong section or I this has been covered elsewhere sorry. I have just brought 2007 350 GT in black and love it to pieces best car I have ever driven! But when I press the button for the boot the catch releases but the boot dosent "pop" up so I have to use two hands to open the boot. Is this normal?? And can you by updated gas struts so that I can make it pop up even if the two handed way is normal?? AND The model I have has the built in factory sat nav can u buy updated DVD's? Or how tricky is it to replace the sat nav with a touch screen jobby but still keepbthe factory look. Thanks guys Quote Link to comment Share on other sites More sharing options...
evilscorp Posted July 21, 2010 Share Posted July 21, 2010 I sometimes have to push the boot opener twice as it does not always totaly unlock(pop) i think its the rubber springs that are the problem not the struts. Mabe add a wee bit more plastic to the end of one, may help but wouldnt know how to do it and make it look standard. Quote Link to comment Share on other sites More sharing options...
Wasso Posted July 21, 2010 Share Posted July 21, 2010 I think the rubber springs you are on about are adjustable - just turn them in a clockwise/anti-clockwise direct I believe to adjust. The SatNav, don't even bother getting a new updated disk. I can't remember how much the dealer quoted but it made me retract very quickly!! Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted July 21, 2010 Share Posted July 21, 2010 Few different remedies: you can replace the gas struts for more powerful ones you can regas them original struts to have a higher pressure you can try the penny mod which invoilves opening the rubber covered springs either side of the boot and putone or two pennys in to give it extra springiness when the boot is popped you can remove the ballast weight that is bolted onto the boot lid under the trim I removed the ballast weight and fixed one of my broken side springs and mine now works with just one press Quote Link to comment Share on other sites More sharing options...
Sarnie Posted July 21, 2010 Share Posted July 21, 2010 SEARCH!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
evilscorp Posted July 21, 2010 Share Posted July 21, 2010 my car only came with one but lucky for me the ppl on here are so nice someone had a spare semi broken one, which they kindly gave me so had to glue some plastic onto the bottom so it would stay in place, now i dare not touch it lol. Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted July 21, 2010 Share Posted July 21, 2010 they are not adjustable are they? if you turn it clockwise or anticlockwise it just falls off?? Quote Link to comment Share on other sites More sharing options...
evilscorp Posted July 21, 2010 Share Posted July 21, 2010 yeh if you turn them they drop out, but there may be a screw at the top under a cap? Quote Link to comment Share on other sites More sharing options...
nurrish Posted July 21, 2010 Share Posted July 21, 2010 I lol'd at 2 handed job Quote Link to comment Share on other sites More sharing options...
Dene8 Posted July 21, 2010 Share Posted July 21, 2010 I lol'd at 2 handed job Yeah i only use one hand.......... Quote Link to comment Share on other sites More sharing options...
Thedancingmexican Posted July 21, 2010 Author Share Posted July 21, 2010 Thanks for all the suggestions! It would seem that my 350 only has one spring is there another good hearted sole with a spare that will part with it for a reasonable price? Or where can I buy a new one/new struts? Quote Link to comment Share on other sites More sharing options...
Dene8 Posted July 21, 2010 Share Posted July 21, 2010 Thanks for all the suggestions! It would seem that my 350 only has one spring is there another good hearted sole with a spare that will part with it for a reasonable price? Or where can I buy a new one/new struts? PM zmanalex, he's a member on here and i'm sure he'll help you out Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 21, 2010 Share Posted July 21, 2010 It took me 5 minutes and 4p to sort my boot out Quote Link to comment Share on other sites More sharing options...
Thedancingmexican Posted July 21, 2010 Author Share Posted July 21, 2010 Where exactly do u put the 2p's in the rubber shoe where the spring is? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 21, 2010 Share Posted July 21, 2010 Where exactly do u put the 2p's in the rubber shoe where the spring is? The Penny Trick - http://www.350z-uk.com/forum/viewtopic.php?f=35&t=37034&hilit=penny+trick As long as the rubber boot stops come off ok you can just take the spring out and put a couple of pennies underneath it, there are pics on the thread. Dont go too mad straight away, especially if you have a spoiler cos you can cause damage! For me 2x1p each side works a treat but I guess it depends how fooked your springs are. Boot pops up nice now, It really annoyed me until I saw the thread on here Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted July 21, 2010 Share Posted July 21, 2010 Where exactly do u put the 2p's in the rubber shoe where the spring is? You actually use 1p pieces but be careful - a lot of people have had the paint crack above because the spring is then sitting too high. Much better to get the struts regassed/uprated instead to do the job properly (having said that I've used the penny trick with no issues ) Quote Link to comment Share on other sites More sharing options...
Wasso Posted July 21, 2010 Share Posted July 21, 2010 I'm sure you can rotate the spring itself once released from the boot lid. It should adjust the ride height of the boot?? If not - then I'm totally wrong.... Nurrish might be able to confirm he's a boot specialist!! Quote Link to comment Share on other sites More sharing options...
Jed Posted July 21, 2010 Share Posted July 21, 2010 had the same problem and never thought about it really except it been a pain in ass opening with 2 hands. Just read the thread n 5 mins and 4p later....Problem solved!!! Great idea! Quote Link to comment Share on other sites More sharing options...
Thedancingmexican Posted July 21, 2010 Author Share Posted July 21, 2010 Where exactly do u put the 2p's in the rubber shoe where the spring is? You actually use 1p pieces but be careful - a lot of people have had the paint crack above because the spring is then sitting too high. Much better to get the struts regassed/uprated instead to do the job properly (having said that I've used the penny trick with no issues ) Do the gas struts open the boot? I though they just stopped it banging you on the head once it was open. I have tried the penny trick but still no joy (mayb cos i only have one boot spring) so ill see if Zmanalex can provide me and go from there. Quote Link to comment Share on other sites More sharing options...
showtime1 Posted July 21, 2010 Share Posted July 21, 2010 i had the same prob two hands to open it then i found that i didnt have any springs so i bought two 36 quid each works a treat now. my car only came with one but lucky for me the ppl on here are so nice someone had a spare semi broken one, which they kindly gave me so had to glue some plastic onto the bottom so it would stay in place, now i dare not touch it lol. Quote Link to comment Share on other sites More sharing options...
Jed Posted August 3, 2010 Share Posted August 3, 2010 Split my paintwork! My fault though as i did read the pro's n con's in this thread! Anyway booked in for a full carbon wrap in October. just got to have my body kit sorted 1st Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted August 3, 2010 Share Posted August 3, 2010 Split my paintwork! My fault though as i did read the pro's n con's in this thread! Anyway booked in for a full carbon wrap in October. just got to have my body kit sorted 1st what kit are you going for? Quote Link to comment Share on other sites More sharing options...
Jed Posted August 3, 2010 Share Posted August 3, 2010 Split my paintwork! My fault though as i did read the pro's n con's in this thread! Anyway booked in for a full carbon wrap in October. just got to have my body kit sorted 1st what kit are you going for? prob the Neo Design Merowing Bodykit. Might changed the rear tho to the vader??? Expression's want me to drop Bumpers n skirts off first so they can be wrapped before rest of car. Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted August 3, 2010 Share Posted August 3, 2010 very different! Look forward to seeing it around Leeds - should make quite an impression, especially in a full carbon wrap! Quote Link to comment Share on other sites More sharing options...
