donaldschen Posted July 15, 2010 Share Posted July 15, 2010 Just got my z. I have mind that Oil reading (There are Battery, Oil PSI, Computer display) changes dramaticlly , the max up to 90 PSI, lowest to 30 PSI. When I accelerated, the reading from 30 to 60 then 90 just in seconds. If I stop or down gear, it back to 30 soon, But before yesterday, I think it escalate after warm. Abnormal? Quote Link to comment Share on other sites More sharing options...
350 Russ Posted July 15, 2010 Share Posted July 15, 2010 No that's normal, it's your oil pressure not level which is what you might have been thinking it was Quote Link to comment Share on other sites More sharing options...
gunmetalzgt Posted July 15, 2010 Share Posted July 15, 2010 That gauge indicates oil pressure not level. Obviously the oil pressure rises when the engine is revved. Sounds normal mate Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted July 15, 2010 Share Posted July 15, 2010 It should come down as it warms up an the oil gets hotter. If this is after about 20 mins then you may have a sensor or oil issue.... Mine does do a bit of moving but only when driving in a spirited fashion! One way to tell if its running right is when its warm to do 60 in 6th and it should read 60psi.. Quote Link to comment Share on other sites More sharing options...
donaldschen Posted July 16, 2010 Author Share Posted July 16, 2010 thanks all. Got it . Am going to change oil today, use Mobile 1 5W30 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 16, 2010 Share Posted July 16, 2010 a good idea to check you dipstick regularly Quote Link to comment Share on other sites More sharing options...
