Mark@Abbey m/s Posted July 15, 2010 Share Posted July 15, 2010 I see lots of people asking whats does and what doesn't work on these cars. People think that you have to fit parts to get any gain form a Uprev this is wrong , these cars need to i,s dotting and T,s crossing even in stock form , if you cant afford anything other than the reflash just have this done you never be unhappy after a reflash. If you want to fit other parts see below; Abbey idea,s; all dyno proven on our Dynapack ( We have had our Dynapack for 8 years) DE 276bhp cars Best tuning mods; Stock airbox with a panel filter ( or find a REVUP 296bhp air box) again fitted with Panel filter these help a lot with inlet temp heat soak but do give the cars more torque than any Race type filter set up) and are quiet Remove stock cats , best De-cats are the Motordyne Resonated Decats but if you dont want to pay the money then stock Decats work , we try to use Berks as they seem the best quality (have used Japspeed these normally require some work to fit correctly) Y pipe we use Motordyne XYZ normally fitted with a Race cat , we find moving the cat away from the headers helps make the car produce torque/bhp and helps smooth the power out. You can always remove the race cats and fit a decat pipe/silencer to give a few more BHP. But running the race cat keeps the car 100% road legal. Motordyne 5/16 base spacer works as well. We reconmend keeping the stock exhaust system , good for 400bhp we have found nice and quiet for everyday use but with the above mods will bark when you floor the throttle. Revup cars; The same as above + we advise to fit a Motordyne Revup lower collector this together with the above mods gives these car the midrange torque that they are missing as a stock car. HR Motors; again same re the exhaust/cats idea as both DE and Rev up engined cars , these we find are best on stock airboxes people like fitting Nismo/Stillen filters kits for the noise but they dont give as much torque/bhp as the stock airbox set up fitted with panel filters. No plenum spacers on these cars thou ;-( hope this all helps I can do a package deal with regards the above mods if people so Link to comment Share on other sites More sharing options...
M13KYF Posted July 15, 2010 Share Posted July 15, 2010 for more info viewtopic.php?f=114&t=38876 Link to comment Share on other sites More sharing options...
