rubbing noise when turning left
Dblock
I get a rubbing noise when turning left and sometimes right. Like tck tck tck tck like its catching on one thing. I dont think its the tyre rubbing as I didnt have that before.
Could be track rod end, ball joint or mor than likely a wheel bearing. Take the wheel off and see whether it has enough grease. Another check compare the heat of both front wheels after a reasonably brake free run.... if it hot it's the bearing.
..... Worth a try :wave::shrug:
