lower arm/ compression rod
r111nxx
hi everyone, Im looking for a new or used lower arm/ compression rod- nissan part 54469 for my z. dealer wants £360 for it which seems a rip off as its only the bush that has gone. also if anyone knows if the bush itself can just be replaced rather than the whole thing. thanks in advance
I know the info is correct on price etc. just ideally wanting a used one rather than shelling out £300. either that or just get a bush if possible (seems to be mixed opinions on this). If you get anymore used ones ZMANALEX i'll take one off ya. cheers
Have a look on eBay. There were a pair listed in America a while back, can't remember the price but I have a feeling it was around $250 for both, excluding shipping. Sill much cheaper than buing here in the UK...
Worth a look at least.
shipping and import tax, to be added so not far off ZMANALEX's price and at least you can go back to Alex if there is a problem
Kit Front & Rear Suspension Bush Kit KIT5261K 1 Contains; 1xSPF3298K, 1xSPF3296K, 1xSPF3299K, 1xSPF2715-50K, 1xSPF2847K, 1xSPF2359-32K, 1xSPF3316K, 1xSPF3318K, 1xSPF3320K, 1xSPF3322K, 1xSPF3313K, 1xSPF2366-20K, 1xSPF3314K, 1xSPF3315K £821.16
Kit Front & Rear Suspension Bush Kit - With Alignment Correction KIT5261ADJK 1 Contains; 1xSPF3298K, 1xSPF3296K, 1xSPF3299K, 1xSPF2715-50K, 1xSPF2847K, 1xSPF2359-32K, 1xSPF3316K, 1xSPF3318K, 1xSPF3320K, 1xSPF3322K, 1xSPF3313K, 1xSPF2366-20K, 1xSPF3314K, 1xSPF3315K £938.74
Kit Front & Rear Running Gear Bush Kit KIT5261K-RG 1 Contains; 1xSPF3298K, 1xSPF3296K, 1xSPF2847K, 1xSPF3316K, 1xSPF3318K, 1xSPF3320K, 1xSPF3322K, 1xSPF3313K, 1xSPF3314K, 1xSPF3315K £676.56
Kit Front Suspension Bush Kit KIT5261FK 1 Contains; 1xSPF3298K, 1xSPF3296K, 1xSPF2847K £221.96
Kit Rear Suspension Bush Kit KIT5261RK 1 Contains; 1xSPF3316K, 1xSPF3318K, 1xSPF3320K, 1xSPF3322K, 1xSPF3313K, 1xSPF3314K, 1xSPF3315K £454.59
F Control Arm Lower, Inner Bush Kit SPF3298K 1 2B,2T,2S £72.07
F Control Arm Upper, Inner Bush Kit SPF3296K 1 8B,4T Standard Alignment £63.06
F Control Arm Upper, Inner Bush Kit SPF3297K 1 8B,4T £135.14
F Shock Absorber Lower Bush Kit SPF3299K 1 2B,2T,2S Bush Located in Control Arm £69.67
F Steering Rack Mounting Bush Kit SPF2715-50K 1 5B,2T For 50mm Tube Diameter £66.37
F Steering Rack Mounting Bush Kit SPF2715-52K 1 5B,2T For 52mm Tube Diameter £66.37
F Strut Bar to Chassis Mounting Bush Kit SPF2847K 1 6B,2T,2S Remove OE Shell for Fitment £120.00
F Strut Bar to Chassis Mounting Bush Kit SPF2849K 1 6B,2T,2S Offset Bushes For Caster Increase, remove OE Shell for Fitment £120.00
F Sway Bar Mount To Chassis Bush SPF2359-_ _K 1 2B Measure bar diameter, 32 & 34mm ava £13.99
R Rear Camber & Toe Adjusting Kit KIT0148K 1 KIT Includes; 1x SPF3321K & 1x SPF3317K £146.31
R Control Arm Lower, Front Inner Bush Kit SPF3316K 1 2B,2T,2S Standard Alignment £69.07
R Control Arm Lower, Front Inner Bush Kit SPF3317K 1 2B,2T,2S Offset Bushes For Camber Increase £69.07
R Control Arm Lower, Front Outer Bush Kit SPF3318K 1 2B,2T,2S Bush Located in Hub £63.06
R Control Arm Lower, Rear Inner Bush Kit SPF3320K 1 2B,2T,2S Standard Alignment £78.08
R Control Arm Lower, Rear Inner Bush Kit SPF3321K 1 2B,2T,2S Offset Bushes For Toe Adjustment £99.10
R Control Arm Lower, Rear Outer Bush Kit SPF3322K 1 2B,2T,2S Bush Located in Hub £72.07
R Control Arm Upper, Inner Bush Kit SPF3313K 1 8B,4T Standard Alignment £63.06
R Control Arm Upper, Inner Bush Kit SPF3313XK 1 8B,4T Offset Bushes For Camber Adjustment £105.11
R Sway Bar Mount To Chassis Bush SPF2366-_ _K 1 2B Measure bar diameter, 20 & 21mm ava £16.18
R Trailing Arm, Front Bush Kit SPF3314K 1 2B,2T,2S £96.10
R Trailing Arm, Rear Bush Kit SPF3315K 1 2B,2T,2S Bush Located in Hub £81.08
