showtime1 Posted July 5, 2010 Share Posted July 5, 2010 need a set of rears soon thinking of running 255/45 or 40 as the avon zz3 are quite narrow compared to other tyres the same size. would this be ok still running the 225 at the fronts. Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 5, 2010 Share Posted July 5, 2010 I can assure you a ZZ3 in 245 will be the same width as a T1R in 245 Stick with the stock width and profile unless you have cause to change them, and then you change them in relation to each other (i.e. you go wider at the front, you go wider at the back). Quote Link to comment Share on other sites More sharing options...
