MRH 350Z Posted July 4, 2010 Share Posted July 4, 2010 Bugger! Someone reversed a mini-bus into my 350Z yesterday and placed a tow-bar shaped hole in the rear bumper! It could have been a lot worse I guess; dissapointing nevertheless! Pics below. [/img] Should be covered by the insurance so not a major issue... I'm getting a Milltek Sports exhaust fitted in the next couple of weeks so glad it didn't happen after the fitting. Anyway: the impact wasn't massive by any means... although big enough to do the obvious damage! Other than the clear need for a new rear bumper is there anything else I should ask the repair company to consider/look for? There doesn't seem to be any other obvious damage and the car drove as normal for 70 miles after the impact. Any advice appreciated. Matt Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted July 4, 2010 Share Posted July 4, 2010 Might even polish out Quote Link to comment Share on other sites More sharing options...
Harman350z Posted July 4, 2010 Share Posted July 4, 2010 Might even polish out Quote Link to comment Share on other sites More sharing options...
MRH 350Z Posted July 4, 2010 Author Share Posted July 4, 2010 Might even polish out Hmmm... some polyfiller maybe..!? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted July 4, 2010 Share Posted July 4, 2010 once your body shop has seen it and assessed the damage, you can push it out to look better until its fixed. take a hair dryer to it or heat gun (becareful if you use it) heat the plastic and you should be able to push it out from behind once the plastic is soft. and to an extent as you heat it; it should return under its own steam. becareful not to blister the paint though. as for the damage thats defo a new bumper; but a good opportunity to fit something aftermarket as most are actually cheaper than a replacement OEM bumper. Quote Link to comment Share on other sites More sharing options...
MRH 350Z Posted July 5, 2010 Author Share Posted July 5, 2010 once your body shop has seen it and assessed the damage, you can push it out to look better until its fixed. take a hair dryer to it or heat gun (becareful if you use it) heat the plastic and you should be able to push it out from behind once the plastic is soft. and to an extent as you heat it; it should return under its own steam. becareful not to blister the paint though. as for the damage thats defo a new bumper; but a good opportunity to fit something aftermarket as most are actually cheaper than a replacement OEM bumper. Thanks for that; I'll certainly give it a go. Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted July 5, 2010 Share Posted July 5, 2010 I had the same thing - towbar into bnack bumpoer while shopping not all bad though as it gave me the poerfect excuse to get an aftermarket bumper on there Quote Link to comment Share on other sites More sharing options...
