showtime1 Posted July 4, 2010 Share Posted July 4, 2010 whats the minimum size spacer you can use without cutting down the bolts on the hub? Quote Link to comment Share on other sites More sharing options...
Husky Posted July 4, 2010 Share Posted July 4, 2010 you mean maximum? EDIT: hang on.. cutting down stock bolts on the hub?? Quote Link to comment Share on other sites More sharing options...
Harman350z Posted July 5, 2010 Share Posted July 5, 2010 Why would you want to spork down your stock bolts with minimum spacers? im confused. Having minimum spacers put on (eg. 5mm) would not affect bolt length, if slotted in would only make them shorter anyways.? Quote Link to comment Share on other sites More sharing options...
Husky Posted July 5, 2010 Share Posted July 5, 2010 beyond confused Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted July 5, 2010 Share Posted July 5, 2010 1mm Quote Link to comment Share on other sites More sharing options...
Harman350z Posted July 5, 2010 Share Posted July 5, 2010 Quote Link to comment Share on other sites More sharing options...
Husky Posted July 5, 2010 Share Posted July 5, 2010 1mm C- "please include working in your answer" Quote Link to comment Share on other sites More sharing options...
UNABASHED Posted July 5, 2010 Share Posted July 5, 2010 1mm C- "please include working in your answer" 1mm seems like a likely contender for being the minimum size of any spacer so I took a punt on it got knows what the OP is talking about Quote Link to comment Share on other sites More sharing options...
Husky Posted July 5, 2010 Share Posted July 5, 2010 i see your logic. well done, grade improved to a B so whos going to angle grind their hub bolts first to see what we are missing out on here? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted July 5, 2010 Share Posted July 5, 2010 actually the minimum spacer you can run is 0mm what i think the OP was trying to ask was, whats the largest spacer i can run without needing new longer studs. and if thats the case then i would say no more than 5mm more likely a 3mm to be safe. personally if your wanting to space the wheels then do it properly with the eibachs Quote Link to comment Share on other sites More sharing options...
Husky Posted July 5, 2010 Share Posted July 5, 2010 3mm rich, i have 3mm ones on and tbh i dont really feel comfortable with it and im still going to put longer studs in. i would guess 5mm would only give you about 2-3turns of the nut Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted July 5, 2010 Share Posted July 5, 2010 3mm rich, i have 3mm ones on and tbh i dont really feel comfortable with it and im still going to put longer studs in.i would guess 5mm would only give you about 2-3turns of the nut i wouldn't want to run any spacer without putting in new longer studs in place. Quote Link to comment Share on other sites More sharing options...
