Sub question
churtz
Hi,
I'm looking to change the sub in my 350. It is a 2008 gt with Bose headunit.
Now, the tricky part. At the moment I wanna keep the Bose head. Has anyone found a way to run a new amp for the sub?
Haven't looked at the wiring at all yet.
Thanks alot,
matt.
Its possible but its a lot of effort for not much more gain. The head unit is the weakest part of the package. You would be better off just upgrading your head unit. This wll improve the overall sound.
You could just use another sub but it will probably sound no better, to get any difference you will also need an amp which will mean converting the line input to the right levels for an amp. Not sure what level the BOSE system uses between the main amp and the sub amp
I think it's that usual mid point between tandard car and home stuff..... :wacko:
