geoff-r Posted July 1, 2010 Share Posted July 1, 2010 I have a standard Bose Sub & Amp here, perfect for replacing faulty Bose audio. I have no use for it now, it came out of a low mileage 350Z. £60 + p&p Quote Link to comment Share on other sites More sharing options...
sketch Posted July 1, 2010 Share Posted July 1, 2010 doesn anyone know if it will work without a bose headunit as i want something compact and hidden like this? and is the hole in the centre of the speaker surpost to be there? also i dont surpose you have the cover with the vent for the sub in it do you? if you have i could swap you for mine which doesnt have and holes etc? very interested, thanks Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted July 1, 2010 Share Posted July 1, 2010 BTW there is also another BOSE amp required to complete the set. Its located inside the standard sub box. Quote Link to comment Share on other sites More sharing options...
geoff-r Posted July 5, 2010 Author Share Posted July 5, 2010 doesn anyone know if it will work without a bose headunit as i want something compact and hidden like this? and is the hole in the centre of the speaker surpost to be there? also i dont surpose you have the cover with the vent for the sub in it do you? if you have i could swap you for mine which doesnt have and holes etc? very interested, thanks I can't really answer your question on it working with a non-Bose headunit or not, I'm sure someone could though. The hole is meant to be in the centre of the sub, I should get a better resolution picture up as this is slightly poor. I don't have the cover with the vent either, I only have what is pictured, thanks. Quote Link to comment Share on other sites More sharing options...
s14akw Posted July 5, 2010 Share Posted July 5, 2010 this sub and amp will work with an aftermarket headunit, but depending on harness may require some alteration Quote Link to comment Share on other sites More sharing options...
