BladesGrant Posted June 30, 2010 Share Posted June 30, 2010 Right I haven't a clue when it comes to installs so need some help. I have bought this HU off another member (been very useful but going on holiday so won't be able to help!!). I have basically bought a new HU with a parrot bluetooth. So this is the parrot unit: I am prety sure I have connect everything to the HU and parrot correctly as they are the only connectors that fit: So now I am only left with the following connectors from the HU / parrot: and these from the back of Bose: As far as I can tell only 2 of these will be required as I am not going to be using steering wheel controls (HU has a remote control). It seems to me the pins are the wrong way round to connect. Does this still require the specific Bose loom to enable to connect these together? I know the pictures might not help that much but thought I would give it a try. Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted June 30, 2010 Share Posted June 30, 2010 Did you not get another loom? There should be a loom which converts the 350z loom (3 white plugs) with the ISO loom that the bluetooth kit has. Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted June 30, 2010 Author Share Posted June 30, 2010 Nope that is pretty much everything I received. The only other cable goes directly into the back of the HU and has loads of RCA style female cables. I presume these are the pre-outs and the aux-in cables. I have just ordered a loom from sextons (ICT 29-674 - Nissan 350z Bose USC Loom) and a double din facia (ICT 50-256 - Nissan 350Z Pre 06 Double Din). Hopefully this will then allow me to connect them all together. Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 1, 2010 Share Posted July 1, 2010 Was this all in another 350Z with bose? Reason i ask is i'm not sure how it will work with the bose amps. The ICT 29-674 loom uses front and rear preouts to provide the signal to the bose amps. The way Parrots work is they have there own internal amp that powers the speakers when making a call etc.. Theres no way of connecting this up to the bose speakers. Ive done a similar install on my mates Vogue and we had to add an extra centre speaker to provide sound when making a call. Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 1, 2010 Author Share Posted July 1, 2010 I presume the previous owner had it installed in their 350z. I can always just install the HU and use the Bluetooth directly with the HU as tat has an external microphone similar to the parrot. Want to get the HU sorted more than anything else. Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted July 1, 2010 Share Posted July 1, 2010 The way Parrots work is they have there own internal amp that powers the speakers when making a call etc.. Theres no way of connecting this up to the bose speakers. Ah yes - your right. If thats the case then there is no way this system is going to work as its designed for a non-amplified system. There may be a way to make it work but the normal leads are not going to work for you. Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 1, 2010 Author Share Posted July 1, 2010 So I will just need to use the loom I have ordered with HU and not with the Parrot? The HU has it's own microphone so can just place that and use the HU directly to call? Quote Link to comment Share on other sites More sharing options...
Harman350z Posted July 1, 2010 Share Posted July 1, 2010 I would of thought it would of been a simple ISO adapter, though i am unfarmilliar with the Z electronics. Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 1, 2010 Author Share Posted July 1, 2010 I thought people used the Parrot with Bose so I don't instant why it wont work with the existing amp, unless I have the wrong Parrot unit. Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 1, 2010 Share Posted July 1, 2010 To get a Parrot system to work with the Bose system you need a Parrot Drive and Talk adaptor which isnt cheap. Check the parrot site for car compatability and it tells you which lead you need depending on which parrot system you have. Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 1, 2010 Author Share Posted July 1, 2010 To get a Parrot system to work with the Bose system you need a Parrot Drive and Talk adaptor which isnt cheap. Check the parrot site for car compatability and it tells you which lead you need depending on which parrot system you have. Top man, thank you. So am I right in thinking that with the loom I have ordred and removing the Parrot unit I shouldn't have a problem with the HU? Thanks. Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 1, 2010 Share Posted July 1, 2010 Yes with the loom it will be a straight swap if you leave out the parrot. The headunit does have front and rear preouts doesnt it? Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 1, 2010 Author Share Posted July 1, 2010 yes it has front and rear pre outs. I have been in contact with the member (even though he is on holiday) and he said the parrot worked fine in his JDM and he had the Bose system. Pointed me in the direction of this: http://www.incarexpress.co.uk/view_product.php?partno=SOT129 Any views? Quote Link to comment Share on other sites More sharing options...
nurrish Posted July 1, 2010 Share Posted July 1, 2010 what head unit did you buy dude? Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 1, 2010 Author Share Posted July 1, 2010 This one with the Parrot: viewtopic.php?f=32&t=37983&p=567299&hilit=time+to+leave#p567299 Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 2, 2010 Author Share Posted July 2, 2010 Right I now have my loom from sextons. What is the wire that is seperate on the HU loom in this picture? viewtopic.php?f=17&t=31260 My HU loom doesn't have a spare wire so I need to know how to connect the J and G wire from the guide above. Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 2, 2010 Share Posted July 2, 2010 The blue wire G is the remote wire, this needs to be connected to the blue wire (remote) on the back of the headunit, it isnt normally seperate like in the picture. I used blue scotch locks to hook everything up, you can get these from halfords. Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 2, 2010 Author Share Posted July 2, 2010 The blue wire G is the remote wire, this needs to be connected to the blue wire (remote) on the back of the headunit, it isnt normally seperate like in the picture. I used blue scotch locks to hook everything up, you can get these from halfords. Cheers for that. Are there any leads out there that will allow the parrot 3200 to work with the Bose amp. I presume it would just come through really loud as its amplified itself? Quote Link to comment Share on other sites More sharing options...
un1eash Posted July 2, 2010 Share Posted July 2, 2010 The parrot site says you need cable PD000114AA but i'd consult an expert as i'm only going by what the parrot site says. The parrot has its only volume control. The way parrots work is they have an input and output for the speakers. When listening to your radio it bypasses the parrot. When making a phone call it mutes the radio and switches to using its own internal amp, this is why theres an issue when connecting to the bose system as the parrots output cant connect to the bose amps. Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted July 2, 2010 Share Posted July 2, 2010 Your probably best emailing parrot to check. As un1eash says the Parrot system will cut the line and amp the speaker it self, you don't want to be sending am amped signal down to the bose amp as it could cause all sorts of problems. Quote Link to comment Share on other sites More sharing options...
