IanS16 Posted June 29, 2010 Share Posted June 29, 2010 Been meaning to post this for a while but keep forgetting Just wanted to say a big thanks to CS and Andy for the work carried out on my car last month, I had the following done: Exedy Clutch Helix Flywheel Braided Clutch line DS2500 Brake Pads x4 Aux Belts MOT Chromolly Clutch Pivot Ball Rear Anti Roll Bar Drop links P3 Service Discs resurfacing Alignment All work was spot on and its a real pleasure to have the car back Only thing I'm still not sure about is the lightweight flywheel, I sound like a transit van on idle and a granny over revving the car on take off Gearbox and clutch are super smooth now after a bit of a realignment and fluid change and now I don't creak like a pirate ship going round corners I did work up quite a list of stuff but was advised out of it as half of it wasn't needed - I appreciate it when a trader gives advice rather than just seeing the £££ Thanks mate Quote Link to comment Share on other sites More sharing options...
bounty78 Posted June 29, 2010 Share Posted June 29, 2010 Well done Mitz and Andy Quote Link to comment Share on other sites More sharing options...
friddela Posted June 30, 2010 Share Posted June 30, 2010 What causes the creaking? I've just started to notice it when I set off at low speeds round corners, thought it was the seat at first! Quote Link to comment Share on other sites More sharing options...
Stew Posted June 30, 2010 Share Posted June 30, 2010 It's usually the drop links. Quote Link to comment Share on other sites More sharing options...
davetstan Posted June 30, 2010 Share Posted June 30, 2010 I did work up quite a list of stuff but was advised out of it as half of it wasn't needed - I appreciate it when a trader gives advice rather than just seeing the £££ Sounds like quite a list there Andy. You must have some deep pockets Same happened to me. You certainly can't beat a trader with superb knowledge and one that has your needs and not just profit in mind. Top work CS as per. Quote Link to comment Share on other sites More sharing options...
