Slimline wheel nuts
SunGodRA
When I fitted new wheels, the OEM nuts were too big to fit, so I had to temporarily use the nuts from my spacers (which I obviously removed! :p )
Spacer nuts:
OEM nuts too big to get socket over:
So I guess I need some slimline nuts - any recommendations?
Found these on ebay http://cgi.ebay.co.uk/Nissan-350-Z-Allo ... _918wt_911 but dont know it they are any good etc...
welcome to the crap world of Small Diameter nuts.
lightweight alloy ones:
Internal Drive Versions - Stay clear! crack extrremely easily! resulting in drilling it off!
External Drive Verions - A little better, but still not ideal, and id always be a tad worried.
Steel Ones:
Internal Drive Versions - By far the best SD Nuts you can buy and also the cheapest!
External Drive Versions -(like the ones you found on ebay) nuts are good, nothing wrong with those, but the removal keys are cack and dont last very long. Especially if you get a stubbron tight nut one day.
  tez162003 said:
is it a slim line socket with a plastic sleeve to stop marking your bolt pockets? there the best for the job :)
Its a normal steel socket - the ones with plastic sleeve didn't fit wheel hole - but wrapping electric tape around it will do the job :thumbs:
