Warranty help!! lots of work needed
350zdriver
course they do mate, it's just that they will have to pay to fix the things ;)
Sounds like most of the UK owners have to stump up as well :) one way or another
not if they go to proper dealers ;)
Yes i'll have to give you that Val. as I have no experience with Nissan dealer . except what I read on here :blush:
seems i have the rattle behind the 3 dash pods at the top aswell (noticed it today). Someone on here mentioned it aswell. Anybody found the source of the annoying thing or had this sorted under warranty? i might just try and fix that one myself.
still loving it though, niggles and all :-))
Rob
Went to the stealers yesterday armed with a list of jobs to do on my Z. They have agreed to do the following free....
clicking rear axle
noisy clutch release bearing/cover springs
pushed the traction control button into the dash (oops)
rattle behind the 3 pods in the dash
Jumping Bose stereo
passenger side heated seat only works on the low setting (bizarre)
Replace both the front and the rear badges.
Only thing they won't do is replace the clutch coer, flywheel or release bearing due to the rattle and very slight judder. They said they would if they could find a fault with it but i would have to pay for the gearbox removal and refit if they don't find a fault (which they'll makee sure they don't!)
So, car should be good as knew by the 4th October!
Regards
Rob
  • 3 weeks later...
clicking rear axle - done
pushed the traction control button into the dash (oops) -done
rattle behind the 3 pods in the dash - done
Jumping Bose stereo - said they couldn't find a fault, aaahhh!!
passenger side heated seat only works on the low setting (bizarre) - new seat base on order.
Replace both the front and the rear badges. -done
squeak from the rear right -done
re-torque front suspension (tsb for slight knock) - done
so basically, all of it, woohoo!!
only problem now is, driving it home from the garage i pulled into Shell, pressed the fuel cap release buttion and that too went straight through the dash! They aren't built too well are they?
regards
Rob
regards
Rob
Your a bit heavy handed :p what you got ? Mars Bars for fingers :teeth:
  • 8 months later...
Are all the warranty issues we have on Uk cars applicable to JDM's? eg Do JDM's get clicky axles?
No......... :p
Mines a JDM and has the clicky axle :(
Sorry Lomoto - ur wrong :-P
Chris
It's your own fault for ragging it Chris :p
