Pads question
andlid
Hi gents,
I'm looking at a pad it's black and it has the following number on the back
lw 2208 90r-01010/2099
does anyone know what pad that would be? I've got 6mm left on the fronts and 9mm on the rears... from what I can gather a EBC pad is 10mm thick, does that go for any pads really or does that differ pads to pads?
Any light?
A
I would guess so. Without seeing them I would guess the discs have quite a ridge on the edge and some fairly obvious grooves around the face of the contact area. Time for some new stuff then! :teeth:
yeah they do look a bit shot... :blush:
(they are from the old calipers and pads, discs...)
New ones are mint :D
What new stuff have you gone for?
Org Brembos with unknown pads (see first post) but loads left in them 6mm from guessing 10mm new front and spanking new rears the discs are 30mm front too (brembo standard I think)
Once the fronts are shot I'll go PF's front ... :teeth:
Next upgrade will be to uprate the lines, very confused to why they did them in three sections?!
