neil354 Posted June 22, 2010 Share Posted June 22, 2010 Hi, just bought a 350z and have just registered as a new user here! I have a quick question regarding the phone kit that came with my car. In the centre console there is what I believe is a phone cradle which is wired in. I can't see any way of removing it. Is there a way that this can be done so that I can get one to fit my phone (iphone)? Also when the phone is connected to this, can you play the music from the phone through the car speakers? Thanks in advance. Neil. Quote Link to comment Share on other sites More sharing options...
Bradders Posted June 22, 2010 Share Posted June 22, 2010 Welcome to the forum There is a slide on either side of the cradle. Steady it with one hand and slide it away with Thumb and forefinger of other hand. It will them lift out. Your can then put bluetooth module in there if you wish. No you can't stream music through the stereo I'm afraid. I'd suggest getting a 3.5 mm tape conversion done and stick it in the cubby hole above the stereo which i had done. Bradders. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 22, 2010 Share Posted June 22, 2010 Hi, just bought a 350z and have just registered as a new user here! I have a quick question regarding the phone kit that came with my car. In the centre console there is what I believe is a phone cradle which is wired in. I can't see any way of removing it. Is there a way that this can be done so that I can get one to fit my phone (iphone)? Also when the phone is connected to this, can you play the music from the phone through the car speakers? Thanks in advance. Neil. Don't remove it ...... just get a bluetooth module (about £70.00) from PIMM and your Iphone hooks up easily ...... you can then use the Nissan voice control actuation buttons on the steering wheel ... and off you go ..... won't play music though .... there are other ways of getting that that are nothing to do with bluetooth Quote Link to comment Share on other sites More sharing options...
narcotix Posted June 22, 2010 Share Posted June 22, 2010 Welcome to the forum Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 22, 2010 Share Posted June 22, 2010 Welcome to the forum yea forgot that bit Wel come Quote Link to comment Share on other sites More sharing options...
neil354 Posted June 23, 2010 Author Share Posted June 23, 2010 Thanks for the replies, I will look at getting a bluetooth adaptor. Cheapest ive seen are on Ebay for about £85. Bradders - what do you mean by a 3.5mm tape conversion? Is this the easiest way of streaming music through the sterio? Quote Link to comment Share on other sites More sharing options...
Bradders Posted June 23, 2010 Share Posted June 23, 2010 You can get a 3.5mm jack or iPhone connector conversion put straight into the tape circuit. So when you hit the tape selector the music will stream from your IPod/Mp3 connecter. R35Lee does one for instance. Bradders. Quote Link to comment Share on other sites More sharing options...
bounty78 Posted June 23, 2010 Share Posted June 23, 2010 +1 what Bradders said. I have one as well Or u could do your own tape deck hack. Do a search on here. Had a go at the DIY mod but mine went a bit tits up..burnt 9 fuses and the IPM. Quote Link to comment Share on other sites More sharing options...
