rawbhp Posted June 21, 2010 Share Posted June 21, 2010 I have a small spot of rust under my fuel filler cap, and another where the rear light joins the rear-quarter panel (pics to follow). Can anyone suggest a good way to treat them and get rid? Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 21, 2010 Share Posted June 21, 2010 get it too a bodyshop and sorted before it becomes serious. once rust starts its wont stop unless you cut out or in mild cases ( just started) cleaned and sanded off completely. Trust me im an expert with rust, my last car was a Ford... Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted June 21, 2010 Share Posted June 21, 2010 depends on what it is. you can get surface contaminants like iron dust in the paintwork that then rusts, i used to get little spots of it. remedy = clay bar, polish and wax if its actual surface rust, and this will only happen if the paint has been broken and bare metal visible then something like rustex applied to the surface will seal it, kill it then touch up paint on top (if its in a non visible place.) Quote Link to comment Share on other sites More sharing options...
rawbhp Posted June 21, 2010 Author Share Posted June 21, 2010 I'm talking a few mm though. Should be able to sort it with the right products. It's only on the the surface. Isn't there some king of anti-corrosion warranty!? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted June 21, 2010 Share Posted June 21, 2010 actually i just remembered i used this green gel i got from B&Q i cant remember what it was called but that was great. It ate away the rust and left only fresh bare metal, and didn't harm paintwork, that was even better. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted June 21, 2010 Share Posted June 21, 2010 I'm talking a few mm though. Should be able to sort it with the right products. It's only on the the surface. Isn't there some king of anti-corrosion warranty!? sounds like a contaminant stuck in the paint is actually rusting, not the actual paint. rust is all but non existent on a zed. apparently places like train station car parks are notoriously bad for iron dust from the tracks. really bad for the paint. needs good paint care etc to keep the car looking good. the iron gets trapped in the paint and then thats what rusts. Quote Link to comment Share on other sites More sharing options...
Biggy Posted June 21, 2010 Share Posted June 21, 2010 If anyones on DW search for a product called iron cut, it's meant to be really good for iron contamination Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 21, 2010 Share Posted June 21, 2010 I used to get patches like that one a few leading edges from stone chips. As Rich says, make sure its actually through the paint and not on the paint. If its through (should be quite obvious, most likely a stone chip), then treat it with Krust from Halfords. It kills off the rust and turns it into a primed surface, ready for a small amount of touch up paint. I did a few places on my old 350z and you couldnt see they were there afterwards and never came back or expanded etc. Quote Link to comment Share on other sites More sharing options...
rawbhp Posted June 21, 2010 Author Share Posted June 21, 2010 Great-thanks for the info guys-I'll sort it. Quote Link to comment Share on other sites More sharing options...
